Setting up DNS records for wildcard sertificate.
Wildcard domain is subdomain: in.site.com
need to have 4nd level subdomains covering: *.in.site.com
DNS is common for all site site.com
TXT DNS settings is set like this:
it was set more than 24hrs ago and it’s doesn’t work
(SOA ttl = 1h)
So, I need wildcard sertificate for subdomain, but I don’t have special DNS for this subdomain, what to do?
That looks like it’s probably correct.
What’s your domain?
mnordhoff, *.in.gallerix.ru
The two TXT
records work for me:
_acme-challenge.in.gallerix.ru. 3600 IN TXT "9u1uni2c8pp7owp5xqszs5lrn2asp3srsl6exfzxvjw"
_acme-challenge.in.gallerix.ru. 3600 IN TXT "f5hhbvzh-eigjo_lqjckiiuysj_upfvskp9ki5ykr2u"
I use Let’sEncrypt plugin for ISP manager, it send me notifications “add TXT to continue”.
What service do you use for dns lookup?
I can see A record only
https://mxtoolbox.com/SuperTool.aspx?action=a%3Ain.gallerix.ru&run=toolpage
https://screenshots.firefox.com/yVh2QfzbxnldLFjB/www.ultratools.com
I used the command line tool dig
You can use MX Toolbox, but you have to change the name to _acme-challenge.in.gallerix.ru
and change the type to TXT
So it looks like plugin problem
Does ISPConfig have a button to continue?
No, it was pending operation awaiting DNS records and finished with error.
What was the error?
Empty message instead error description, ISPmanager don’t know this error.
Trying to find anything in logs.
syslog:
Dec 24 14:41:05 gallerix named[734]: zone gallerix.ru/IN: ‘gallerix.ru’ found SPF/TXT record but no SPF/SPF record found, add matching type SPF record
Dec 24 14:41:04 [601:31234] core_module e[1;36mEXTINFO Internal [letsencrypt][dim] 'args=&func=check.domaintxt&name=value&value=3U5MwDeuZEMP3CrkmwpdjJBPBd65vtwI6OC9vTeMT8M’e[0m
Dec 24 14:41:04 [601:31234] core_decoration e[1;36mEXTINFO New value value = '3U5MwDeuZEMP3CrkmwpdjJBPBd65vtwI6OC9vTeMT8M’e[0m
Dec 24 14:41:04 [601:31234] proc e[1;36mEXTINFO Run ‘/usr/sbin/named-checkzone gallerix.ru. /etc/bind/gallerix.ru’ pid 7976e[0m
Dec 24 14:41:04 [601:31234] proc e[1;36mEXTINFO Process 7976 finished with status 0e[0m
Dec 24 14:41:04 [601:31234] proc e[1;36mEXTINFO Run ‘/usr/sbin/named-checkzone gallerix.ru. /etc/bind/gallerix.ru’ pid 7977e[0m
Dec 24 14:41:04 [601:31234] proc e[1;36mEXTINFO Process 7977 finished with status 0e[0m
Dec 24 14:41:04 [601:31234] dns e[1;36mEXTINFO Update command ignorede[0m
Dec 24 14:47:02 [601:31269] proc 1;36mEXTINFO Run ‘/bin/sh -c dig\ _acme-challenge.in.gallerix.ru.\ TXT\ 8.8.8.8\ 8.8.4.4\ 77.88.8.8\ 77.88.8.1\ 1.1.1.1\ +noall\ +answer’ pid 22008 0m
Dec 24 14:47:02 [601:31269] proc 1;36mEXTINFO Process 22008 finished with status 0 0m
