My domain is: wageindicator.org
certbot certonly --webroot -w /var/www/acme-challenge/ --cert-name wageindicator.org -d wageindicator.org -d euroccupations.org -d wageindex.eu -d workindicators.com -d www.euroccupations.org -d www.wageindex.eu -d www.wageindicator.org -d www.workindicators.com
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/wageindicator.org.conf)
What would you like to do?
1: Keep the existing certificate for now
http-01 challenge for euroccupations.org
http-01 challenge for wageindex.eu
http-01 challenge for wageindicator.org
http-01 challenge for workindicators.com
http-01 challenge for www.euroccupations.org
http-01 challenge for www.wageindex.eu
http-01 challenge for www.wageindicator.org
http-01 challenge for www.workindicators.com
Using the webroot path /var/www/acme-challenge for all unmatched domains.
Failed authorization procedure. wageindicator.org (http-01): urn:ietf:params:acme:error:dns :: DNS problem: SERVFAIL looking up CAA for wageindicator.org - the domain's nameservers may be malfunctioning, www.wageindicator.org (http-01): urn:ietf:params:acme:error:dns :: DNS problem: SERVFAIL looking up CAA for wageindicator.org - the domain's nameservers may be malfunctioning
Domain: wageindicator.org
Type: None
Detail: DNS problem: SERVFAIL looking up CAA for wageindicator.org
Domain: www.wageindicator.org
Type: None
root@ciney:/etc/letsencrypt/renewal# certbot certonly --webroot -w /var/www/acme-challenge/ --cert-name wageindicator.org -d wageindicator.org -d euroccupations.org -d wageindex.eu -d workindicators.com -d www.euroccupations.org -d www.wageindex.eu -d www.workindicators.com
You are updating certificate wageindicator.org to include new domain(s):
(None)
You are also removing previously included domain(s):
- www.wageindicator.org
Did you intend to make this change?
(U)pdate cert/(C)ancel: u
Running deploy-hook command: systemctl reload nginx
/etc/letsencrypt/live/wageindicator.org.conf/fullchain.pem
/etc/letsencrypt/live/wageindicator.org.conf/privkey.pem
Your cert will expire on 2021-12-14. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew *all* of your certificates, run
"certbot renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
My web server is (include version): nginx/1.14.2
The operating system my web server runs on is (include version): Debian GNU/Linux 10 (buster)
My hosting provider, if applicable, is: VPS uses linode.com (hostname ciney.wageindicator.org
), DNS is managed at openprovider.eu
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): n/a
or certbot-auto --version
if you're using Certbot): certbot 0.31.0
When I run the certbot command without www.wageindicator.org
the certificates get renewed:
(None)
"certbot renew"
I did try to search for this problem related to DNS CAA and have read this doc Certificate Authority Authorization (CAA) - Let's Encrypt. We don't have CAA enable for wageindicator.org
. I tried debugging this error using several site which analyze DNS records, and run several dig command but could not find what exactly is wrong.
Several sites I've use to find out what is wrong:
https://unboundtest.com/m/CAA/wageindicator.org/ZU7U2L2K
https://dnssec-debugger.verisignlabs.com/www.wageindicator.org
https://dnsviz.net/d/wageindicator.org/dnssec/
