DNS problem: SERVFAIL looking up CAA for ga
www.magnusbrzenk.ga
sudo certbot --apache
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated)  (Enter 'c' to cancel): www.magnusbrzenk.ga
http-01 challenge for www.magnusbrzenk.ga
Enabled Apache rewrite module
Failed authorization procedure. www.magnusbrzenk.ga (http-01): urn:ietf:params:acme:error:dns :: DNS problem: SERVFAIL looking up CAA for ga
   Domain: www.magnusbrzenk.ga
   Type:   None
   Detail: DNS problem: SERVFAIL looking up CAA for ga
Apache/2.4.29 (Ubuntu)
Ubuntu 18.04
AWS Lightsail
Yes
No
certbot 0.31.0
Also:
I figured I'd give AWS lightsail a trial, so I redirected a free domain I set up
(magnusbrzenk.ga) from a preivous target to a new target on AWS lightsail.
Certbot worked fine with this domain with the previous target, but now it keeps failing with
`DNS problem: SERVFAIL looking up CAA for ga`. Any ideas what this is all about?
It looks like the registry operator for the ga TLD (Freenom?) is having some issues. I can reproduce your issue with a different domain of mine (acmedev.ga).
Until they fix their nameservers, there is one workaround available to you, and that’s to create your own CAA record:
magnusbrzenk.ga. 360 IN      CAA     0 issue "letsencrypt.org"
OK, thanks for the info. Doesn’t look like freenom will let me create CAA records. I’ll check back in a day or two.
OK, it’s working now :slight_smile:
