DNS problem: SERVFAIL looking up A for
I am trying to generate a new cert and I am getting the error bellow. I am not seeing problems with A records for that domain, as per nslookup tests:
nslookup
set q=NS
monikericci.com.br
Server: 8.8.8.8
Address: 8.8.8.8#53
Non-authoritative answer:
monikericci.com.br nameserver = ns2.clicregistro.info.
monikericci.com.br nameserver = ns.clicregistro.info.
Authoritative answers can be found from:
server ns.clicregistro.info
Default server: ns.clicregistro.info
Address: 143.137.191.36#53
set q=A
www.monikericci.com.br
Server: ns.clicregistro.info
www.monikericci.com.br canonical name = app.simplo7.net.
server ns2.clicregistro.info
Default server: ns2.clicregistro.info
Address: 143.137.191.37#53
set q=A
Server: ns2.clicregistro.info
monikericci.com.br
certbot certonly --webroot -w /mnt/nfs/stores/static/20514/ -d monikericci.com.br,www.monikericci.com.br --email suporte@dlojavirtual.com --agree-tos --no-eff-email --manual-public-ip-logging-ok --deploy-hook /etc/letsencrypt/renewal-hooks/deploy/deploy.sh --noninteractive
http-01 challenge for www.monikericci.com.br
Using the webroot path /mnt/nfs/stores/static/20514 for all unmatched domains.
Challenge failed for domain www.monikericci.com.br
    Domain: www.monikericci.com.br
    Type: dns
    Detail: DNS problem: SERVFAIL looking up A for
Apache/2.4.6
Centos7
NA
No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.0.0
Hi @afagund
checking that domain there are problems visible - https://check-your-website.server-daten.de/?q=monikericci.com.br
X Fatal error: Nameserver doesn't support TCP connection: ns.clicregistro.info / 143.137.191.36: Timeout
X Fatal error: Nameserver doesn't support TCP connection: ns1.alojasegura.com.br: Timeout
X Fatal error: Nameserver doesn't support TCP connection: ns2.clicregistro.info / 143.137.191.37: Timeout
Same with Unboundtest:
https://unboundtest.com/m/A/www.monikericci.com.br/UQVTRMBR
Jan 22 13:38:08 unbound[14074:0] info: response for ns2.clicregistro.info. AAAA IN
Jan 22 13:38:08 unbound[14074:0] info: reply from <clicregistro.info.> 143.137.191.36#53
Jan 22 13:38:08 unbound[14074:0] info: query response was nodata ANSWER
Jan 22 13:38:08 unbound[14074:0] error: tcp connect: Connection refused for 143.137.191.36 port 53
So your name servers are buggy.
@JuergenAuer, should’nt DNS queries go via por 53 UDP and zone transfers via 53 TCP? Why 53 TCP would be causing this issue?
Authoritative name servers must support TCP-connections.
https://www.iana.org/help/nameserver-requirements
Name server reachability
The name servers must answer DNS queries over both the UDP and TCP protocols on port 53.
So a connection refused is critical. Letsencrypt checks such things with an unbound configuration like Unboundtest. So Unboundtest fails -> Letsencrypt will fail.
@JuergenAuer, thanks for clarifying.
