DNS problem: query timed out looking up A for www.yardsale.com
www.yardsale.com
php acmephp.phar run configYSonly.yml
In AcmeClient.php line 200:
Challenge failed (response: {“type”:“http-01”,“status”:“invalid”,“error”:{"
type":“urn:ietf:params:acme:error:connection”,“detail”:“dns :: DNS problem:
query timed out looking up A for www.yardsale.com”,“status”:400},“url”:“ht
tps://acme-v02.api.letsencrypt.org/acme/challenge/NATMQlcVINM2st4EgU_8
8L-L7uYxNZxe-tVTad-JZr0/18529021217”,“token”:“zdjnbEoJzzkIQEDF6c5fwTuGiG6I
DNVjYa_cPI_UkE0”}).
Worldgroup 6.0
windows 2008
no
Acme PHP - Let’s Encrypt client 1.1.1
It used to work 3 months ago. When I run it, I see it attempting to access my web server via the log
I think probably this is probably due to misconfigured glue records for the domain of your nameservers (worldgroupware.com).
$ dig +noall +additional @i.gtld-servers.net worldgroupware.com
dns.worldgroupware.com. 172800  IN      A       71.246.247.62
dns2.worldgroupware.com. 172800 IN      A       50.76.18.33
But 50.76.18.33 is wrong. It doesn’t even run an authoritative nameserver.
The real record should be:
dns2.worldgroupware.com. 2804   IN      A       71.246.247.34
This usually isn’t a fatal error, but I have a feeling that in this case, Let’s Encrypt’s resolver has some kind of intolerance against it (even though I can’t reproduce it by running Unbound myself). So it tries using that glue record and for some reason ends up in a timeout.
yeah I saw that 50…33 addr. I’m not sure where it was coming from. What is this dig command? I imagine it’s a unix thing. Is there a windows equivalent?
What I wonder is why it worked 3 months ago, nothings really change in my config. thanks for taking the time to answer this!
It's set in the "nameserver registration" or "glue" or similar settings for worldgroupware.com at its domain registrar.
ah thanks! I think I found it!
well that was it. There is a cool site called http://dnsviz.net and it also confirmed these glue record issues. I’m running my own DNS using SimpleDNS+ and it all seemed good there. So I went to my domain register and under the worldgroupware domain there was this “child name servers” stuff. and that’s where I saw it had a wrong (old) IP address. Once I fixed this all was well in my world.
