After resolving this issue Timeout during connect (likely firewall problem) I now run into this issue.
I deliberately removed the AAAA-Record from da.wikihoster.net. Challenge should be done via IPv4 only. Again I am at a loss. Any help appreciated to get this working without an AAAA-Record.
My domain is: da.wikihoster.de
I ran this command: certbot certonly --webroot -w /var/www/htdocs/mw/02140 -d da.wikihoster.de --dry-run
http-01 challenge for da.wikihoster.de
Using the webroot path /var/www/htdocs/mw/02140 for all unmatched domains.
Failed authorization procedure. da.wikihoster.de (http-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up A for da.wikihoster.de - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for da.wikihoster.de - check that a DNS record exists for this domain
Domain: da.wikihoster.de
Type: None
Detail: DNS problem: NXDOMAIN looking up A for da.wikihoster.de -
My web server is (include version): Apache/2.4.38 (Debian)
The operating system my web server runs on is (include version): Debian GNU/Linux 10 (buster)
My hosting provider, if applicable, is: IN-Berlin (privately maintained though)
The version of my client is: certbot 0.31.0
