Warning: The domain 'ampsers.com' resolves to a different IP address than the
one detected for this machine, which is '65.1.153.139'. Please fix its DNS
entries or remove it. For more info see:
https://docs.bitnami.com/general/faq/configuration/configure-custom-domain/
Press [Enter] to continue:
My web server is (include version): AWS Lightsail
The operating system my web server runs on is (include version): Linux Bitnami WordPress on AWS Lightsail
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Certbot 0.31.0
Previously I had another Lightsail instance on my AWS server on which I was able to generate a certificate using the command sudo certbot -d $DOMAIN -d $WILDCARD --manual --preferred-challenges dns certonly . I deleted that instance and created a new one and attached the previous static IP to the new one. But now even for this command it is giving some DNS problem error.
Well, that looks allright to me. Why would bncert-tool complain about it, if everything looks good? Weird.. Not sure what's going on, perhaps it'll work now somehow?
I'm trying to ignore/suppress the fact that I had deleted a Lightsail instance before and replaced that with a new one which I'm running now, by attaching it with the previous static IP. Is that a matter of concern?
Additional response to "perhaps it'll work now somehow?" - - I've been trying to make it work and have been saying that to myself for the past 48+ hours..
I just wanted to let you all/everybody know that this problem was rectified by adding the TXT record in the "Route 53" also. I followed the second method which I have posted in this thread.
Glad you've got yourself a certificate, but note that if you don't actually require a wildcard certificate (and thus require the dns-01 challenge), the preferred method is one that can be automated. Such as the http-01 challenge in stead of the dns-01 challenge.
Also, you say your DNS runs on Route53, right? Because there's also a Route53 DNS plugin which can be automated.
