client. If youâre using the webroot plugin, you should also verify
ibm-server:/srv/www/htdocs/nextcloud/config # httpd-prefork -v
Server version: Apache/2.4.33 (Linux/SUSE)
Server built: 2019-08-28 06:00:22.000000000 +0000
local server
I can login to a root shell on my machine (yes or no, or I donât know):
Iâm using a control panel to manage my site (no, or provide the name and version of the control panel):
The version of my client is (e.g. output of certbot --version or certbot-auto --version if youâre using Certbot):
certbot 0.24.0
i have this certificate produced on a other virtual machine. but this machine dosnât more exist. also i will change the servername und create an new certificate for my nextcloud
port 80 ist open in firewall and in the router (fritzbox) forwarded.
from an other intern client i can connect:
holger@pc-ho-lin:~> wget 172.17.1.254
â2019-09-04 21:42:31-- http://172.17.1.254/
Verbindungsaufbau zu 172.17.1.254:80 ⌠verbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet ⌠400 Bad Request
2019-09-04 21:42:32 FEHLER 400: Bad Request.
or
holger@pc-ho-lin:~> lynx --dump 172.17.1.254
This application requires JavaScript for correct operation. Please
[1]enable JavaScript and reload the page.
Nextcloud
Access through untrusted domain
Please contact your administrator. If you are an administrator, edit
the âtrusted_domainsâ setting in config/config.php like the example in
config.sample.php.
Further information how to configure this can be found in the
[2]documentation.
The problem was found and solved. In the router (Fritzbox) was a filter list active, which has blocked the HTTP server protocol for the local home server. Certificate are now ok, all the best, THANK YOU
