Dns Certbot broke my DNS Can someone please help me fix it. I had no snapshot
My domain is:chrislarivey.com
I ran this command:sudo certbot --apache
It produced this output: it worked the second time I tried it
My web server is (include version): latest apache
The operating system my web server runs on is (include version): latest ubuntu
My hosting provider, if applicable, is: AWS
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Hi @cwl_is_me
Certbot can't break your DNS, that's not possible. And with certbot --apache your dns isn't changed.
Checking your domain there is a simple error - https://check-your-website.server-daten.de/?q=chrislarivey.com
• http://chrislarivey.com/
3.219.22.196 301 https://chrislarivey.com/ 0.230 A
• http://www.chrislarivey.com/
3.219.22.196 200 0.240 H
• https://chrislarivey.com/
3.219.22.196 200 1.400 B
• https://www.chrislarivey.com/
3.219.22.196 200 1.147 N
Certificate error: RemoteCertificateNameMismatch
Your non-www works, your www not. Reason: Your certificate
CN=chrislarivey.com
	17.06.2019
	15.09.2019
expires in 90 days	chrislarivey.com - 1 entry
has only one domain name, the www version is missing.
So create one certificate with both domain names - chrislarivey.com and www.chrislarivey.com.
Thanks for the help.
I tried to use sudo certbot --apache and it didn’t work. Is there a different command to add www.chris larivey or a command to delete what I have so I can start over.
Thanks again
Doesn't Certbot show both domains?
If not, your vHost configuration may be wrong.
Has your vHost a
ServerName chrislarivey.com
ServerAlias www.chrislarivey.com
note that you have a limit of 5 duplicate certificates in a week, so if you keep on trying again and again the same command hoping to get a different result you will get to this limit. Not that will block you to get a certificate for the 2 names since it’s counted as a different certificate.
I can’ t seem to find the httpd or conf.d in etc. It has to be there.
I have put the server name and alias in both the 443 and 80 configuration file. My site is still not up.
Did you restart certbot ? If yes and it did not work what was the output ?
Hi @cwl_is_me,
Is your webserver running? From my testing I don’t believe it is.
$ telnet chrislarivey.com 80
Trying 54.221.150.148...
^C
$ telnet chrislarivey.com 443
^C
What is the output from the following commands?
systemctl status apache2
ps aux | grep apache
apache2ctl -S
If apache is NOT running, see if it will restart
sudo systemctl restart apache2
It says that apache is running. I checked after I did restart.
How can I restart certbot?
I meant run it manually like you did last time, I think it was certbot --apache
I saw both there this time when I ran certbot --apache
I did get this though
Domain: www.chrislarivey.com
Type: connection
Detail: dns :: DNS problem: NXDOMAIN looking up A for
Now you have removed your DNS www entry ( https://check-your-website.server-daten.de/?q=chrislarivey.com ):
chrislarivey.com A 54.221.150.148
Beaumont/Texas/US yes 1 0
AAAA yes
www.chrislarivey.com Name Error yes 1 0
So this domain name doesn't have an ip address, so you can't create a certificate via http-01 validation.
Add a DNS A entry.
I have this in route 53 for a static ip address 3.219.22.196
I also see records there for both an alias www.chrislarivey.com and an a record
These are not public visible.
So that can't work.
as said by @JuergenAuer
dig @ns-1074.awsdns-06.org chrislarivey.com A +short
54.221.150.148
-> good
dig @ns-1074.awsdns-06.org www.chrislarivey.com A +short
-> bad (no IP address)
also on both addresses your should be able to do a wget
wget chrislarivey.com
and
wget www.chrislarivey.com
That’s my route 53 zone. If I understand correctly I have a problem in route 53, not my web server.
Your screenshot has nothing to do with your public visible values ( https://check-your-website.server-daten.de/?q=chrislarivey.com ):
AAAA yes
There is no CNAME of the non-www version. And the www version doesn't have an A (ipv4) or AAAA (ipv6) record.
Maybe a "private zone" or something else.
Your name servers are:
chrislarivey.com
	•  ns-1074.awsdns-06.org / d23e598e3a96b5ffe1b039cdfda72041 -
	205.251.196.50
Seattle/Washington/US	•
	2600:9000:5304:3200::1
	•  ns-2008.awsdns-59.co.uk / a016776f7bbc82045b760fc896198650 -
	205.251.199.216
	2600:9000:5307:d800::1
	•  ns-235.awsdns-29.com / 8d11ee001268fdda1377c036589eb73b -
	205.251.192.235
	2600:9000:5300:eb00::1
	•  ns-744.awsdns-29.net / e69f46562e3217bfe5d667766445f4ca -
	205.251.194.232
	2600:9000:5302:e800::1
	•  ns-865.awsdns-44.net / a50c7c46d74217c10ed26284a8fbf9f5 -
	205.251.195.97
	2600:9000:5303:6100::1
There you have to change your settings.
54.221.150.148 is not my public IP address. Mine is 3.219.22.196
