I am running my website with Opencart. my site was non-ssl before, I had HTML code in the description of all 10,000 products listed on my Opencart website and that HTML code was using a flash file which was stored in a sub-folder, so the path is something like this;
http://www.mydomain.com/abcd/…
Now I have installed SSL, everything works fine but that particular HTML code in all 10,000 products cannot find the file inside a sub-folder abcd, this is because now the path should be
https://www.mydomain.com/abcd/…
But i can’t change the path in all 10,000 products. So I decided to exclude this subfolder “abcd” from SSL
I am not a script developer and do not understand how to write new rules for .htaccess at all. I would really appreciate i you could please guide me thought step by step simple instructions with an easy example or a code line which i can just copy and paste to .htaccess file and it should start working.
Any help would be much appreciated by this layman.
