`--disable-hook-validation` - output when failed?
Hey everyone
I have a --deploy-hook that was recognized by certbot (see below), but never executed. I checked certbot --help renew and it mentions --disable-hook-validation.
My question is, if said validation fails and the hook does not go through, would that be mentioned in the logs? And if yes, what am I looking for?
Right now, when I search for deploy-hook or just hook in my log, I am only seeing:
INFO:certbot.compat.misc:Running deploy-hook command: /etc/letsencrypt/renewal-hooks/deploy/ntpsec
Please help
Notes:
When I say recognized by certbot, I mean I am seeing this at the top of my log file:
DEBUG:certbot._internal.main:Arguments: ['--non-interactive', '--standalone', '--http-01-port', '8008', '--allow-subset-of-names', '--deploy-hook', '/usr/bin/chown -R www-data "$RENEWED_LINEAGE" && /usr/bin/chown -R www-data /etc/letsencrypt/archive && /usr/bin/systemctl reload nginx']
certbot version 1.12.0
(A related followup: Will `--deploy-hook` run if `/etc/letsencrypt/renewal-hooks/deploy/ntpsec` exists?. It could be that --deploy-hook doesn't work not because it fails validation but because I have at least one script in /etc/letsencrypt/renewal-hooks/deploy.)
(A quick question related to https://community.letsencrypt.org/t/disable-hook-validation-output-when-failed/229340.)
I pass a --deploy-hook argument to certbot. It is recognized, but does not get executed. In the log, however, I see a mention of /etc/letsencrypt/renewal-hooks/deploy/ntpsec being executed.
lets encrypt - LetsEncrypt certbot multiple renew-hooks - Stack Overflow says:
Note: On newer (early 2023) versions, you cannot use multiple --pre-hook (or others hooks). Each new directive of the same name will overwrite the previous one.
So I wanted to confirm if --deploy-hook is ignored because I have at least one script in /etc/letsencrypt/renewal-hooks/deploy.
Certbot version 1.12.0
Thank you!
No clue as regard to your original question, but you should not WANT nor should you NEED to make www-data the owner of the files in /etc/letsencrypt/{live,archive}/. The private key should only be able to read by root and not by the unprivileged user the webserver is running as.
A deploy-hook will not execute if validation failed. It only runs when a cert is issued.
Have you reviewed the Certbot docs? Search the page below for --deploy-hook to better understand how it should work. When testing with --dry-run, which is recommended, you will need to specify extra options to ensure the --deploy-hook runs
https://eff-certbot.readthedocs.io/en/latest/using.html#certbot-command-line-options
I'm pretty sure OP doesn't mean validation like hostname validation, but the checks Certbot does (like, is the script executable) before attempting to run the hook.
Yes, the certs for which I expect the hook to run are indeed issued. Sorry, forgot to mention that. It's an important detail.
Ah, did you try it with --disable-hook-validation?
I think you will just have to experiment on your own. Certbot v1.12 is over 3Y old and makes it difficult for anyone to try to reproduce. I am pretty sure you should be able to have a deploy-hook command line option and also in the deploy hook folder, generally.
When I have problems with hooks I make one doing just "echo In-Hook-ABC". I use --dry-run with the extra needed option to run deploy-hooks.
Even if you identify a problem the Certbot team will want to know whether it fails in a recent version. An actual bug against Certbot is best reported at the EFF's github for it: Issues · certbot/certbot · GitHub
They will want a description of an easy way to reproduce the problem though. Like: I have this in deploy hook folder, I use these options on command line and get this but not that and show entire log.
Getting back to your original specific question ... Set a deploy-hook with an obviously incorrect path and see what shows in the log. Try with and without the "disable" option to see if that matters.
