Difference between .pem and .crt and how to use them
ubuntu 20.04
Yes
HestiaCP
1.27
I need to be able to create a .cre file from the .pem.
I noticed that in /etc/letsencrypt/archive/my-domain/
the fullchain1.pem has 3 certificate blocks
Like this ( I have taken some lines out for brevity )
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----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bHbvO5BieebbpJovJsXQEOEO3tkQjhb7t/eo98flAgeYjzYIlefiN5YNNnWe+w5y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The openssl is supposed to convert to a .crt file
When I run this:
openssl x509 -outform der -in fullchain1.pem -out new.crt
root@expressresponse:/etc/letsencrypt/archive/gldn.page# cat new.crt
0▒&0▒▒▒y▒H▒▒▒▒▒▒/q▒▒0
021
0 UUS10U
Let's Encrypt1
▒0▒90518
▒H▒▒010UR30 gldn.page0▒"0
▒▒ž▒▒▒Yi▒'m▒▒Se▒▒▒u▒▒]▒▒▒▒"OۀNDz▒▒(;~▒▒=▒▒'+^▒\▒!▒<▒▒lsk>▒H▒▒▒▒▒[9▒▒=▒wXR▒▒wƷ@l5▒S^▒▒cs▒▒▒▒▒ͯ>▒▒▒▒h"▒ d▒▒#▒▒6SD-▒m▒▒▒▒▒A▒▒LAk#▒A▒ң▒▒V8▒]FhQqiޡ▒Zr>c▒▒▒▒▒▒$▒7ʋ|▒ :4U▒;▒▒/H=8▒▒c▒U
▒▒F▒▒▒Gx▒▒▒▒R0▒N0U▒▒0U%+0
U▒00U▒▒(▒▒!Ӵ0M
(▒▒'▒▒MK0U#0▒.▒▒XVˮP @▒▒▒▒▒▒0+I0G0+0▒http://r3.o.lencr.org0+0▒http://r3.i.lencr.org/0!U0▒
.gldn.page▒ gldn.page0LU E0Cg▒
07
+▒▒0(0+http://cps.letsencrypt.org0▒
+▒y▒▒▒▒▒wߥ^▒h▒Ol▒▒_N>Z▒͢▒j^▒;▒ D*s▒?▒▒H0F!▒▒▒▒<▒▒▒▒L▒▒
W▒K%fp▒▒%(▒!▒s_▒|End▒Թ▒հ▒P▒
▒H▒▒ &▒y3p▒▒vF▒U▒u▒ 0▒▒▒i▒▒},At▒▒I▒▒▒▒▒p▒mG▒?G0E $▒M▒5▒▒a▒&▒G▒▒6hԡ▒N|▒_▒<▒▒
!▒▒▒,o▒xB▒7&w▒▒}▒ZT▒#▒2t▒U2Gw▒0
▒1▒K>QY▒~
▒M▒j▒f▒{w!>▒k▒4Q▒▒@▒h▒oGq
'▒▒▒▒u▒;▒P▒և▒)▒Ì▒A▒3▒▒]▒cݻ▒5▒▒▒*▒z▒s▒▒▒▒t>NHbM▒U99xJhXw"▒▒▒=?▒▒▒▒aC▒ו▒H^▒%▒▒▒Jq▒>▒mn▒{;▒▒7
▒R#Lf▒▒▒U▒▒▒K▒I▒6.▒▒3▒0▒P▒▒U▒▒▒▒▒
▒.z▒▒́c▒ YB▒▒+▒G$l▒▒E▒w▒QsV▒ ▒▒pFs▒w▒@▒▒'▒▒▒▒h▒root@expressresponse:/etc/letsencrypt/archive/gldn.page# PuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTY
Is the output supposed to look like this?
If the .crt file is just one of those certificates, can I just cut it out with vim ?
Also would be nice to know what those 3 certificates are for?
Is one the public key? Which one?
Thanks
A .crt file is often the same as a .pem file, it's just called .crt so you know what's in the file. Same with .key. There are other encoding's like der (which you are trying to convert the pem encoded file to here), but you probably don't need that unless the service you are configuring explicitly requires it.
The PEM encoded files produced by certbot include:
  • cert.pem - just your pem encoded cert, also the public key
  • chain.pem - the other intermediate certs that make up the certificate chain (not including the root)
  • fullchain.pem - your cert, plus the intermediates, this is often the file you need
  • privkey.pem - your private key
You can convert or combine these files in different ways depending on how you want to use them, so the question is what type of service are you trying to use the cert for?
Thanks for the info.
I am trying to get the SL certs I have for wildcards
i.e gldn.page, *.gldn.page to work properly on HestiaCP
( HestiaCP doesn't handle wildcard SL certs )
I changed the template it uses to point at the SL certs I have already created.
SSLVerifyClient none
    ssl_certificate /etc/letsencrypt/live/%domain%/fullchain.pem; # ma>
    ssl_certificate_key /etc/letsencrypt/live/%domain%/privkey.pem; # >
Which looked fine,
but when the domain didn't resolve ssl, I was told I needed to run this:
v-add-web-domain-ssl dave gldn.page /etc/letsencrypt/live/gldn.page
But I get this:
Error: /etc/letsencrypt/live/gldn.page/gldn.page.crt not found
Then I was told "Hestia converts .pem into .crt files"
and was shown a bit of code:
492. # Splitting up downloaded pem
493. crt_end=$(grep -n 'END CERTIFICATE' $ssl_dir/$domain.pem |head -n1 |cut -f1 -d:)
494. head -n $crt_end $ssl_dir/$domain.pem > $ssl_dir/$domain.crt
* pem_lines=$(wc -l $ssl_dir/$domain.pem |cut -f 1 -d ' ')
495. ca_end=$(grep -n 'BEGIN CERTIFICATE' $ssl_dir/$domain.pem |tail -n1 |cut -f 1 -d :)
496. ca_end=$(( pem_lines - crt_end + 1 ))
497. tail -n $ca_end $ssl_dir/$domain.pem > $ssl_dir/$domain.ca
* debug_log "CERT CRT" "$(cat "$ssl_dir/$domain.crt")"
498. debug_log "CERT CA-1" "$(cat "$ssl_dir/$domain.ca")"
499. # Temporary fix for double "END CERTIFICATE"
500. if [[ $(head -n 1 $ssl_dir/$domain.ca) = "-----END CERTIFICATE-----" ]]; then
501. sed -i '1,2d' $ssl_dir/$domain.ca
502. fi
503. debug_log "CERT CA-2" "$(cat "$ssl_dir/$domain.ca")"
It looks like this code is splitting up the .pem file rather than the real convert that I did with openssl.
Can you tell which part of the .pem file I need to cutt out and call a .crt file?
Hope this all makes sense !
Thanks.
That script seems to be https://github.com/serghey-rodin/vesta/blob/master/bin/v-add-web-domain-ssl and for whatever reason it's expecting to find $domain.crt and $domain.key in the path you give it.
You could copy fullchain.pem to gldn.page.crt, and copy privkey.pem to gldn.page.key then run that script again, maybe that would work.
Note sure if you already followed their guide but you may want to see if your process is the same as: Getting Started | Hestia Control Panel
Thanks for the suggestion:
Error: Certificate Authority not found
What could this be?
It looks like you're combining nginx with Apache configurations? To me, it doesn't look "fine".
Interestingly this error message cannot be found in the Hestia source code :thinking:
Looking at that script it's sometimes looking for a $domain.ca file. I'd guess that might be the CA root certificate it's looking for, but I have no idea really. See Getting Started | Hestia Control Panel
It looks to me like HestiaCP prefers you to use their various letsencrypt specific commands rather than try to configure stuff yourself: Getting Started | Hestia Control Panel
That code is from here: https://github.com/serghey-rodin/vesta/blob/0fcbadda783926fdae681e7ad5bc2cd279aa7c90/bin/v-add-letsencrypt-domain#L321-L351
@webprofusion didn't directly state the following - though if you read between the lines on his answer - you might have understood it. I just want to this to be clear:
Traditionally, the .crt file extension denotes a DER encoded certificate with an application/x-x509-server-cert mime header (and .cer denotes DER encoding with application/pkix-cert mime header). None of this is required by spec, and a .crt can - and often does - contain PEM encoded content.
Back to the problem...
The source in that specific letsencrypt command may help you figure out how they want certificates set up. The section after downloading the certificate is how they add it to the system and the section after that registers a renewal.
