Detail: DNS problem: query timed out looking up A for cloud.moulard.org
I have problem to renew my certificat. see a copy of my DIG.
Could you have a idée oe one piste to explore?
GM
root@cloud:~# /usr/bin/letsencrypt renew
Processing /etc/letsencrypt/renewal/cloud.moulard.org.conf
tls-sni-01 challenge for cloud.moulard.org
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/cloud.moulard.org.conf produced an unexpected error: Failed authorization procedure. cloud.moulard.org (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: query timed out looking up A for cloud.moulard.org. Skipping.
/etc/letsencrypt/live/cloud.moulard.org/fullchain.pem (failure)
    Domain: cloud.moulard.org
    Type: connection
    cloud.moulard.org
    root@cloud:~# dig cloud.moulard.org
; <<>> DiG 9.10.3-P4-Ubuntu <<>> cloud.moulard.org
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 20780
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;cloud.moulard.org. IN A
;; ANSWER SECTION:
cloud.moulard.org. 85509 IN A 84.39.33.18
;; Query time: 2 msec
;; SERVER: 185.23.94.244#53(185.23.94.244)
;; WHEN: Mon May 01 22:06:32 UTC 2017
;; MSG SIZE rcvd: 62
It's not at your end, there seems to be an issue with Let's Encrypt DNS servers.
Seems the DNS issues have been fixed now, all is working for me, you may want to retry.
