Issue while renew
My domain is: www.abc.gov.in
I ran this command: sudo certbot renew
    Domain: www.abc.gov.in
    Type: dns
    Detail: DNS problem: query timed out looking up A for
    www.abc.gov.in; DNS problem: query timed out looking up AAAA
    for www.abc.gov.in
The operating system my web server runs on is (include version): AWS Linux
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Certbot version : 1.11.0
here is the Letsdebug out put :
[IssueFromLetsEncrypt](https://letsdebug.net/www.abc.gov.in/2452845#Issue FromLetsEncrypt-Error)
A test authorization for www.abc.gov.in to the Let's Encrypt staging service has revealed issues that may prevent any certificate for this domain being issued.
DNS problem: query timed out looking up A for www.abc.gov.in; DNS problem: query timed out looking up AAAA for www.abc.gov.in
it was successfully renew from last 1 year. no configuration changed on server.
Hello @ujjawal,
Please show the output of each of the following commands
  • sudo certbot certificates
  • sudo apachectl -t -D DUMP_VHOSTS
You might want to consider upgrading Certbot;
see Certbot 4.0.0 released
Edit
There are also significant DNS issues see these
Presently I believe this is the first issue to be solved, as Let's Encrypt uses Multi-Perspective Validation Improves Domain Validation Security - Let's Encrypt
Since these are Domain Validation (DV) certificates the Domain Name System (DNS) is used extensively in the validation process as well a allowing us to assist here on Let's Encrypt community.
DNS Queries need to give consistent results from any location on the Internet, all your authoritative DNS Servers for the Domain need to also give consistent results as well.
so DNS server issue is the culprit right ? is it possible that DNS sever is blocking queries from some location because when i use dig command, from my host machine it gives me proper response and answers.
is it due to any geo blocking firwall ?
I don't see you ever getting a Let's Encrypt certificate. Only ones from Amazon or Sectigo
Your previous thread (see here) I described the changes you need to make to your CAA records to allow Let's Encrypt to issue a cert. That doesn't affect the error you describe in this thread but it will be a problem if you want a Let's Encrypt cert. Do you?
This thread's problem to the Let's Encrypt staging system is related to your DNS servers. Some of them do not reply properly. That is difficult to test with dig commands but see DNSViz Errors for detailed errors.
