--deploy-hook not executed after staging cert successfully obtained
I am testing certbot in docker container of debian through automated deployment. For purposes of the project I created a bash script that is following:
#!/usr/bin/env bash
# inspired by Secure plesk clean installation with hostname certificate by Let's Encrypt · GitHub
# this script name is used for first cert generation, after that renewal is done by certbot cron
HOSTNAME=$1
certbot \
certonly \
--webroot \
-w /var/www/certbot/ \
--email myemailaddress@mydomain.com \
-d "${HOSTNAME}" \
--non-interactive \
--agree-tos \
--deploy-hook "/usr/sbin/nginx -t ; /usr/sbin/nginx -s reload ; touch /etc/letsencrypt/reloadok" \
--server https://acme-staging.api.letsencrypt.org/directory
echo "Certificate generation finished for hostname ${HOSTNAME}"
Now the problem is that when I execute that for testing purposes the certs are generated, all files are properly created. However nginx is never restarted, the touch file never created and folder /etc/letsencrypt/renewal-hooks/deploy/ is empty. It never seems to execute the hooks. --deployment hook should be executed every single time cert is retreived or renewed.
I tried command certbot renew --dry-run and it was performing all actions properly, but it did not show skipping any renewal hooks either :frowning:
For purposes of public forum I obstructed the real domain with privatedomain text, since it is a corporate project.
My domain is: private corporate, cannot disclose
I ran this command: as mentioned in script above
http-01 challenge for privatedomain
Using the webroot path /var/www/certbot for all unmatched domains.
    /etc/letsencrypt/live/privatedomain/fullchain.pem
    /etc/letsencrypt/live/privatedomain/privkey.pem
    Your cert will expire on 2019-04-09. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot
    again. To non-interactively renew all of your certificates, run
    "certbot renew"
    Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
    Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
Certificate generation finished for hostname privatedomain
root@dfe8ef633758:/app# nginx -v
nginx version: nginx/1.15.7
Certbot version:
root@dfe8ef633758:/app# certbot --version
certbot 0.28.0
root@dfe8ef633758:/app# cat /etc/debian_version
9.6
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): nope
Any help is appreciated how to solve the issue. could it be permission issues ? but certifficates were issued and written properly by user executing the script.
Hmm OK, actually it does work. Definitely it was a permission issue, but somehow certbot command could not execute the post installation hook. we made sure that the /etc/letsencrypt folder has proper flags assigned and it seem to be working correctly. if anybody will use this thread as inspiration for script feel free to. can be closed as resolved
