Deleted older GIT letsencrypt now Apache will not start repost
I posted this a little more than a month ago but have not been able to resolve. If anyone can give me some help as to how I can get apache going to make my domains available to letsencrypt so I can replace the deleted certs I’d be very grateful.
"Last months post"
Early in the year I setup letsencrypt from GIT. It never updated automatically. At the time there was no apt package for Debian Jessie but since there is now I decided to remove letsencrypt and reinstall from apt-get. I followed the instructions from the forum as follows:
"Warning: This will delete ALL certificates (including private keys), account keys, renewal configuration and log files. Don’t run this unless you have a good reason to!
You might also be interested in the config_changes or rollback subcommands for the apache plugin, allowing you to view or revert changes made to your apache configuration.
Off the top of my head, this should remove any traces:
rm -rf /path/to/your/git/clone/directory
rm -rf ~/.local/share/letsencrypt
rm -rf /etc/letsencrypt
rm -rf /var/log/letsencrypt
rm -rf /var/lib/letsencrypt
(Let me know if I missed anything!)"
After removing I installed letsencrypt from apt-get and now apache will not start. I get the following error when I try to start apache:
root@LinuxServer:/etc/letsencrypt/live# service apache2 start
Job for apache2.service failed. See ‘systemctl status apache2.service’ and ‘journalctl -xn’ for details.
root@LinuxServer:/etc/letsencrypt/live# journalctl -xn
– Logs begin at Fri 2016-10-21 18:00:36 EDT, end at Wed 2016-11-09 19:18:37 EST. –
Nov 09 19:18:37 LinuxServer systemd[1]: Starting LSB: Apache2 web server…
– Subject: Unit apache2.service has begun with start-up
– Defined-By: systemd
– Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
– Unit apache2.service has begun starting up.
Nov 09 19:18:37 LinuxServer apache2[25571]: Starting web server: apache2 failed!
Nov 09 19:18:37 LinuxServer apache2[25571]: The apache2 configtest failed. … (warning).
Nov 09 19:18:37 LinuxServer apache2[25571]: Output of config test was:
Nov 09 19:18:37 LinuxServer apache2[25571]: apache2: Syntax error on line 140 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/mods-enabled/php5.load: Cannot load /usr/lib/a
Nov 09 19:18:37 LinuxServer apache2[25571]: Action ‘configtest’ failed.
Nov 09 19:18:37 LinuxServer apache2[25571]: The Apache error log may have more information.
Nov 09 19:18:37 LinuxServer systemd[1]: apache2.service: control process exited, code=exited status=1
Nov 09 19:18:37 LinuxServer systemd[1]: Failed to start LSB: Apache2 web server.
– Subject: Unit apache2.service has failed
– Unit apache2.service has failed.
– The result is failed.
Nov 09 19:18:37 LinuxServer systemd[1]: Unit apache2.service entered failed state.
I am not an expert with using Linux so any concise help would be greatly appreciated.
Thanks…
Dave
"End of last months post"
My domain is: davidovad.com
I ran this command: certonly --webroot -w /var/www/davidovad -d davidovad.com -d vpn.davidovad.com -d news.davidovad.com -d owncloud.davidovad.com -d linuxserver.davidovad.com -d server.davidovad.com -d wiki.davidovad.com -d blog.davidovad.com
It produced this output: Failed authorization procedure. blog.davidovad.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to blog.davidovad.com, server.davidovad.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to server.davidovad.com, wiki.davidovad.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to wiki.davidovad.com, davidovad.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to davidovad.com, linuxserver.davidovad.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to linuxserver.davidovad.com, owncloud.davidovad.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to owncloud.davidovad.com, news.davidovad.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to news.davidovad.com, vpn.davidovad.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to vpn.davidovad.com
    Domain: blog.davidovad.com
    Type: connection
    Detail: Could not connect to blog.davidovad.com
    Domain: server.davidovad.com
    Type: connection
    Detail: Could not connect to server.davidovad.com
    Domain: wiki.davidovad.com
    Type: connection
    Detail: Could not connect to wiki.davidovad.com
    Domain: davidovad.com
    Type: connection
    Detail: Could not connect to davidovad.com
    Domain: linuxserver.davidovad.com
    Type: connection
    Detail: Could not connect to linuxserver.davidovad.com
    Domain: owncloud.davidovad.com
    Type: connection
    Detail: Could not connect to owncloud.davidovad.com
    Domain: news.davidovad.com
    Type: connection
    Detail: Could not connect to news.davidovad.com
    Domain: vpn.davidovad.com
    Type: connection
    Detail: Could not connect to vpn.davidovad.com
    root@LinuxServer:/home/dovad# nano /etc/apache2/sites-available/default-ssl.conf
    root@LinuxServer:/home/dovad# apt-gat update^C
    root@LinuxServer:/home/dovad# service apache2 restart
    root@LinuxServer:/home/dovad# apache2-ssl-certificate
    bash: apache2-ssl-certificate: command not found
My operating system is (include version): Debian 8
My web server is (include version): Apache/2.4.10 (Debian)
My hosting provider, if applicable, is: hosted at home
Are there any clues at the locations it states ....
What is near those lines
I also wonder if you could do
grep -r /etc/letsencrypt /etc/apache2
to see if there are any references to the deleted certificates still present in your config files (which would definitely make Apache have trouble starting, but I wouldn’t expect it to produce exactly the error messages that you’re seeing).
