I have configured tomcat inside docker container as follows
<Connector port="8443" protocol="org.apache.coyote.http11.Http11NioProtocol"
maxThreads="150" SSLEnabled="true">
<SSLHostConfig>
<Certificate certificateKeystoreFile="my.jks"
type="RSA" />
</SSLHostConfig>
</Connector>
<Connector port="8443" protocol="org.apache.coyote.http11.Http11AprProtocol"
maxThreads="150" SSLEnabled="true" >
<UpgradeProtocol className="org.apache.coyote.http2.Http2Protocol" />
<SSLHostConfig>
<Certificate certificateKeyFile="/etc/letsencrypt/live/example.com/privkey.pem"
certificateFile="/etc/letsencrypt/live/example.com/cert.pem"
certificateChainFile="/etc/letsencrypt/live/example.com/chain.pem"
type="RSA" />
Restarted the docker container but its not accessible via https
where my.jks is stored inside tomcat/conf directory.
I configure docker container as follows:
docker run -d \
--name=nameofcontainer \
-p 80:8080 \
-p 443:8443 \
--net=cyclos-net \
--cap-add=NET_ADMIN \
-e DB_HOST=cyclos-db \
-e DB_NAME=cyclos \
-e DB_USER=cyclos \
-e DB_PASSWORD=cyclos \
image-id
Phil
May 15, 2019, 1:10pm
2
Hi muazzamazaz, welcome to the community.
Can you show me the output if you curl -viL ${DOCKER_IP_ADDR} the container on port 80 and 443?
Your configuration looks very similar to this blog post, I assume this is what you followed? https://mvysny.github.io/Lets-Encrypt-with-Docker-Tomcat/
Another possible config to look at would be https://github.com/AtomGraph/letsencrypt-tomcat
root@4b0535d06a77:/usr/local/cyclos# curl -viL ${DOCKER_IP_ADDR}
curl: no URL specified!
I just installed certbot and set paths of .pem files in server.xml. After that I have restarted docker container as I see in docker cyclos container tomcat is installed but not able to access it as service.
I have tried to connect via telnet at port 80 and 8443, but only port 80 works
https://members.kentuckianatrade.com:8443/
Phil
May 20, 2019, 3:51pm
6
Hi @muazzamazaz ,
Inside the container the example ${DOCKER_IP_ADDR} variable should be 127.0.0.1. Outside the container it should be something like
$ sudo docker inspect -f '{{range .NetworkSettings.Networks}}{{.IPAddress}}{{end}}' sdf1234
172.17.0.2
What do your catalina logs say about the TLS configuration or when you try to access port 8443? Inside the container do you see a process bound to port 8443 netstat -plunt ?
Can you try configuring tomcat per the document at https://tomcat.apache.org/tomcat-8.0-doc/ssl-howto.html ? The doc states you should include at least scheme="https" in your connector options.
muazzamazaz:
After commenting this connector it gets working as two different SSL protocols were configured on same port.
<SSLHostConfig>
type="RSA" />
</SSLHostConfig>
</Connector>
SSL Imlementation - Server Fault Post
system
Closed
June 20, 2019, 7:36am
8
