Curl: (35) Unknown SSL protocol error in connection to acme-v02.api.letsencrypt.org:443
We are trying to install wildcard ssl but this error comes up
innercirclegamingclub.com
curl -v https://acme-v02.api.letsencrypt.org/directory
  • Trying 172.65.32.248...
  • TCP_NODELAY set
  • Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
  • ALPN, offering h2
  • ALPN, offering http/1.1
  • Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
  • successfully set certificate verify locations:
  • CAfile: /etc/ssl/certs/ca-certificates.crt
    CApath: /etc/ssl/certs
  • TLSv1.2 (OUT), TLS header, Certificate Status (22):
  • TLSv1.2 (OUT), TLS handshake, Client hello (1):
  • Unknown SSL protocol error in connection to acme-v02.api.letsencrypt.org:443
  • Curl_http_done: called premature == 0
  • Closing connection 0
    curl: (35) Unknown SSL protocol error in connection to acme-v02.api.letsencrypt.org:443
apache
debian9
vultr
no
not using
Hi @naveedkumbhar, welcome to the LE community forum :slight_smile:
Please show the output of:
curl --version
and test to another site, like:
curl -v https://google.com/
Is this happening consistently on every attempt? How long does the connection take before getting the error?
Thanks @rg305
the output of curl --version
curl 7.52.1 (x86_64-pc-linux-gnu) libcurl/7.52.1 OpenSSL/1.0.2u zlib/1.2.8 libidn2/2.2.0 libpsl/0.17.0 (+libidn2/0.16) libssh2/1.7.0 nghttp2/1.18.1 librtmp/2.3
Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
Features: AsynchDNS IDN IPv6 Largefile GSS-API Kerberos SPNEGO NTLM NTLM_WB SSL libz TLS-SRP HTTP2 UnixSockets HTTPS-proxy PSL
out put of different site curl -v https://google.com/
*   Trying 172.217.175.46...
* TCP_NODELAY set
* Connected to google.com (172.217.175.46) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-ECDSA-AES128-GCM-SHA256
* ALPN, server accepted to use h2
* Server certificate:
*  subject: CN=*.google.com
*  start date: Sep 13 01:38:37 2021 GMT
*  expire date: Nov 20 01:38:36 2021 GMT
*  subjectAltName: host "google.com" matched cert's "google.com"
*  issuer: C=US; O=Google Trust Services LLC; CN=GTS CA 1C3
*  SSL certificate verify ok.
* Using HTTP2, server supports multi-use
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
* Using Stream ID: 1 (easy handle 0x556d7b79bed0)
> GET / HTTP/1.1
> Host: google.com
> User-Agent: curl/7.52.1
> Accept: */*
* Connection state changed (MAX_CONCURRENT_STREAMS updated)!
< HTTP/2 301
< location: https://www.google.com/
< content-type: text/html; charset=UTF-8
< date: Fri, 01 Oct 2021 17:36:54 GMT
< expires: Sun, 31 Oct 2021 17:36:54 GMT
< cache-control: public, max-age=2592000
< server: gws
< content-length: 220
< x-xss-protection: 0
< x-frame-options: SAMEORIGIN
< alt-svc: h3=":443"; ma=2592000,h3-29=":443"; ma=2592000,h3-T051=":443"; ma=2592000,h3-Q050=":443"; ma=2592000,h3-Q046=":443"; ma=2592000,h3-Q043=":443"; ma=2592000,quic=":443"; ma=2592000; v="46,43"
<HTML><HEAD><meta http-equiv="content-type" content="text/html;charset=utf-8">
<TITLE>301 Moved</TITLE></HEAD><BODY>
<H1>301 Moved</H1>
The document has moved
<A HREF="https://www.google.com/">here</A>.
</BODY></HTML>
* Curl_http_done: called premature == 0
* Connection #0 to host google.com left intact
This may or may not be the source of your problem, but OpenSSL 1.0.2 is no longer supported. I would recommend before spending more time debugging this problem, update your operating system to get a newer version of OpenSSL (and many other packages).
this is happening whenever i try
