My domain is: deteque.tana.it
Attempting to renew cert (deteque.tana.it) from /etc/letsencrypt/renewal/deteque.tana.it.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,). Skipping.
/etc/letsencrypt/live/deteque.tana.it/fullchain.pem (failure)
My web server is (include version): Apache 2.4
The operating system my web server runs on is (include version): Debian 9
My hosting provider, if applicable, is: n/a
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.28.0
I have two files in http://deteque.tana.it/.well-known/acme-challenge/, probably created when I first installed the certificate. BTW, this is the target url af a deteque rpz, and the certificate served for a (failed) attempt to redirect rpz’ed https traffic to a fixed page.
Question: should I change the cron script or the config file? And how?
Additional question: is it possible to run certbot not as root? How do I switch to making it belonging to a user? (Since this certificate doesn’t work anyway, I can as well start it over from scratch. )
TIA
Ale
