Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | maison.francois.cc), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: maison.francois.cc
I ran this command: Create new cert from synology interface
It produced this output: Cannot validate this domain name
My hosting provider, if applicable, is: Free; fixed IP
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Synology 7.0.1
Your IPv4 and your IPv6 point to different machines (or your server is listening differently on them.) (No, not really, nmap isn't telling that, but you should still check it. Ok, I'm changing my mind again, nmap tells me that, if I scan the standard ports instead of port 80 alone.)
IPv4 needs port forwarding but each device on your network has their own public IPv6 address. You need to use the right one, the IPv4 for the router but the IPv6 for the actual device.
% nmap -6 -A -Pn -p80 maison.francois.cc
Starting Nmap 7.92 ( https://nmap.org ) at 2022-03-28 09:37 CEST
Nmap scan report for maison.francois.cc (2a01:e0a:834:5780:a2ce:c8ff:fee8:8e96)
Host is up (0.00044s latency).
Other addresses for maison.francois.cc (not scanned): 82.64.71.225
PORT STATE SERVICE VERSION
80/tcp filtered http
Host script results: | address-info:
| IPv6 EUI-64:
| MAC address: | address: a0:ce:c8:e8:8e:96
|_ manuf: CE Link Limited
Service detection performed. Please report any incorrect results at https://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 1.22 seconds
% nmap -4 -A -Pn -p80 maison.francois.cc
Nmap scan report for maison.francois.cc (82.64.71.225)
Host is up.
Other addresses for maison.francois.cc (not scanned): 2a01:e0a:834:5780:a2ce:c8ff:fee8:8e96
rDNS record for 82.64.71.225: 82-64-71-225.subs.proxad.net
Nmap done: 1 IP address (1 host up) scanned in 2.89 seconds
% nmap -4 -A -Pn maison.francois.cc
Starting Nmap 7.92 ( https://nmap.org ) at 2022-03-28 09:45 CEST
Host is up (0.096s latency).
Not shown: 998 filtered tcp ports (no-response)
5000/tcp open http nginx
|_http-title: Site doesn't have a title.
| http-robots.txt: 1 disallowed entry
|_/
5001/tcp open ssl/http nginx
| ssl-cert: Subject: commonName=francois.familyds.net
| Subject Alternative Name: DNS:*.francois.familyds.net, DNS:francois.familyds.net
| Not valid before: 2022-02-16T04:23:28 |_Not valid after: 2022-05-17T04:23:27
|_ssl-date: TLS randomness does not represent time | http-robots.txt: 1 disallowed entry
|_/
|_http-title: ELMHOME_DATA - Synology DiskStation
Nmap done: 1 IP address (1 host up) scanned in 57.23 seconds
% nmap -6 -A -Pn maison.francois.cc
Starting Nmap 7.92 ( https://nmap.org ) at 2022-03-28 09:47 CEST
Host is up (0.00026s latency).
All 1000 scanned ports on maison.francois.cc (2a01:e0a:834:5780:a2ce:c8ff:fee8:8e96) are in ignored states.
Not shown: 1000 filtered tcp ports (net-unreach)
| address-info:
| IPv6 EUI-64:
| MAC address:
Nmap done: 1 IP address (1 host up) scanned in 1.63 seconds
