Can't create certificate for 1 domain on Synology others do work on same NAS
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=welzijnsmasseur.nl), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: welzijnsmasseur.nl
I ran this command: Get a certificate via GUI from Synology NAS
It produced this output: Failed to connecto to Let’s Encrypt. Please make sure the domain name is valid.
My web server is (include version): Synology Webstation
My hosting provider, if applicable, is: mijndomein.nl
I can login to a root shell on my machine (yes or no, or I don’t know): I don’t know
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): I don’t know
On the same synology NAS I am running 2 different websites with a certificate from Let’s Encrypt without any problem. Only difference those domains are hosted by a different hosting company.
Hi @baspeels
there is a check of your domain ( https://check-your-website.server-daten.de/?q=welzijnsmasseur.nl ):
There you see the problem.
You have ipv4- and ipv6 addresses:
welzijnsmasseur.nl A 81.204.230.39
Rhenen/Provincie Utrecht/NL yes 1 0
AAAA 2a00:4e40:1:1::2:20b
Lelystad/Flevoland/NL yes
www.welzijnsmasseur.nl A 81.204.230.39
But your http + /.well-known/acme-challenge has different answers:
• http://welzijnsmasseur.nl/
81.204.230.39 301 https://welzijnsmasseur.nl/ 0.047 A
2a00:4e40:1:1::2:20b 200 0.047 H
• http://www.welzijnsmasseur.nl/
81.204.230.39 200 0.063 H
2a00:4e40:1:1::2:20b 200 0.030 H
• https://welzijnsmasseur.nl/
81.204.230.39 200 0.843 N
Certificate error: RemoteCertificateNameMismatch
2a00:4e40:1:1::2:20b -14 10.014 T
Timeout - The operation has timed out
• https://www.welzijnsmasseur.nl/
81.204.230.39 200 0.563 N
2a00:4e40:1:1::2:20b -14 10.016 T
• http://welzijnsmasseur.nl/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
81.204.230.39 301 https://welzijnsmasseur.nl/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.047 A
Visible Content: 301 Moved Permanently nginx
Visible Content:
• http://www.welzijnsmasseur.nl/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
81.204.230.39 404 0.127 A
Not Found
Visible Content: © 2019 Synology Inc.
2a00:4e40:1:1::2:20b 200 0.046
Visible Content:
• https://welzijnsmasseur.nl/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de -14 10.017 T
Visible Content:
http + ipv4 is redirected to https, http + ipv6 not. And ipv6 answers with a http status 200, not the expected status 404 - Not Found.
So
  • remove your ipv6, then create a certificate, then fix your ipv6 (or)
  • fix your ipv6
But Letsencrypt prefers ipv6, so that's critical.
Thanks for pointing me in the right direction, I removed ipv6 settings at domain registrar under dns settings. Recreated the certificate and that worked. I will test it for some days and renew it in a few days. Then I will try to fix the ipv6 settings, but tried to find my ipv6 address, but can’t find it. I used whatsmyip.com
whatsmyip shows you the ip address of your local computer.
So if you don't have a configured ipv6, that can't work.
And that service looks wrong.
Your Public IPv4: 162.158.114.98
IPv6: 2a01:238:301b::1229
The ivp6 is correct, the ipv4 is completely wrong.
I get the same thing.
The website’s using Cloudflare, and the IPv4 IPs are Cloudflare IPs. It appears they’re failing to use the X-Forwarded-For header or whatever and reporting Cloudflare’s proxy server IP as “your” IP.
Yep - 162.158.114.98 is Cloudflare Berlin. :wink:
But I’m not Cloudflare and I don’t use it.
