Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: X.X.tech
I ran this command: I followed the below process,
I can bet almost any IT technician have heard of Letsencrypt certificates. They are completely free and fully supported by big corps such as Google, Facebook, Microsoft, and many others, to have a more secure and privacy-respecting Web. A lot of...
It produced this output: Type :
Url :
Token :
Status :
Error :
Identifier : dns:X.X.tech
Data :
ResourceUrl : https://acme-v02.api.letsencrypt.org/acme/order/1460432416/228620585156
Status : invalid
Expires : 2023-12-19T06:31:37Z
NotBefore :
NotAfter :
Identifiers : {dns:X.X.tech}
AuthorizationUrls : {https://acme-v02.api.letsencrypt.org/acme/authz-v3/292840342806 }
FinalizeUrl : https://acme-v02.api.letsencrypt.org/acme/finalize/1460432416/228620585156
CertificateUrl :
CSROptions : AcmeCsrOptions
My web server is (include version): Using application gateway
My hosting provider, if applicable, is: NA
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NA
Osiris
December 12, 2023, 7:42am
2
Here you can find the actual error:
104.40.147.146: Fetching http://acona-dev.bosch.tech/.well-known/acme-challenge/flxT3fv0kTjJqTNgJdllj-9ZTAvUfug2cki-OL2qdA4: Timeout during connect (likely firewall problem)
You need to make sure that IP address is reachable on port 80 from the public internet.
Thanks!! which IP i have to whitelist? My automation account is not inside the network. So can you please suggest which IP needs to be whitelisted?
Osiris
December 12, 2023, 12:12pm
4
There's nothing to whitelist: Let's Encrypt validates from multiple vantage points and these IP addresses can and do change without warning.
Again I have received the same error. So with Azure can you please confirm what do i need to allow?
Trying to get a new certificate for X.X.tech
ResourceUrl : https://acme-v02.api.letsencrypt.org/directory
NewAccount : https://acme-v02.api.letsencrypt.org/acme/new-acct
NewAuthz :
NewNonce : https://acme-v02.api.letsencrypt.org/acme/new-nonce
NewOrder : https://acme-v02.api.letsencrypt.org/acme/new-order
KeyChange : https://acme-v02.api.letsencrypt.org/acme/key-change
RevokeCert : https://acme-v02.api.letsencrypt.org/acme/revoke-cert
Meta : AcmeDirectoryMeta
KeyId
UimiYl39npsXtxCevCss1pF71YMuVbydkpxH3e5OOOoRORwqhw4
Type : http-01
Token : pqU0kEg5LEKEJ -wS2XkltIdZLNZdBNFzxJTaER7qA
Filename : pqU0kEg5LEKEJ -wS2XkltIdZLNZdBNFzxJTaER7qA
RelativeUrl : /.well-known/acme-challenge/pqU0kEg5LEKEJ -wS2XkltIdZLNZdBNFzxJTaER7qA
AbsoluteUrl : acona-dev.bosch.tech/.well-known/acme-challenge/pqU0kEg5LEKEJ -wS2XkltIdZLNZdBNFzxJTaER7qA
Content : pqU0kEg5LEKEJ -wS2XkltIdZLNZdBNFzxJTaER7qA.mzG7rcIn7OKVLf_1cq06n3bxxMUpt-3yIBiPMlIaJkI
ICloudBlob : Microsoft.Azure.Storage.Blob.CloudBlockBlob
BlobType : BlockBlob
Length : 87
IsDeleted : False
BlobClient : Azure.Storage.Blobs.BlobClient
BlobBaseClient : Azure.Storage.Blobs.Specialized.BlockBlobClient
BlobProperties : Azure.Storage.Blobs.Models.BlobProperties
RemainingDaysBeforePermanentDelete :
ContentType : application/octet-stream
LastModified : 12/12/2023 12:06:47 PM +00:00
SnapshotTime :
ContinuationToken :
VersionId :
IsLatestVersion :
AccessTier : Hot
TagCount : 0
Tags :
Context : Microsoft.WindowsAzure.Commands.Storage.AzureStorageContext
Name : .well-known/acme-challenge/pqU0kEg5LEKEJ -wS2XkltIdZLNZdBNFzxJTaER7qA
Type :
Url :
Token :
Status :
Error :
Data :
ResourceUrl : https://acme-v02.api.letsencrypt.org/acme/order/1460914116/228675213766
Status : invalid
Expires : 2023-12-19T12:06:43Z
NotBefore :
NotAfter :
AuthorizationUrls : {https://acme-v02.api.letsencrypt.org/acme/authz-v3/292914842866 }
FinalizeUrl : https://acme-v02.api.letsencrypt.org/acme/finalize/1460914116/228675213766
CertificateUrl :
rg305
December 12, 2023, 3:22pm
6
Source: 0.0.0.0/0
port: 80
But if we allow all the IPs then its a risk right? to the application
If you allow access to 443 from anywhere, also allowing access to 80 isn't really more of a risk.
If your site is closed and only allows internal users to connect, then you need to either (1) script allowing for anyone to be able to connect when doing a renewal, or (2) use the DNS-01 challenge method instead which requires scripting updates to your DNS server.
When you get a certificate from Let’s Encrypt, our servers validate that you control the domain names in that certificate using “challenges,” as defined by the ACME standard. Most of the time, this validation is handled automatically by your ACME...
system
Closed
January 14, 2024, 4:23pm
9
