Creating batch of certificates using script
My domain is: Multiple domains
My web server is (include version): Nginx 1.10.3
The operating system my web server runs on is (include version): Debian 9
Hello
I have a about 200 domains hosted on my Nginx server, and domains will get added from time to time. I’m trying to write a script that will automatically add SSL to these domains. What would be my options? From my understanding with certbot, I would have to manually input information by hand.
I don’t know what language your backend is, but I’m pretty sure you’re better off chosing a library from the list of ACME implementations, so you can integrate Let’s Encrypt into your backend directly.
Certbot, the way I see it, is more a client for end-users to use directly.
Manually?
The whole point of LE is automation...
You could call a script with variables that uses certbot with those parameters.
I don't really see how you can implement it easily / generically; as:
  • you can't run as --standalone (you already serve many sites from https there)
  • you can't forward all http to https (any new site won't have https yet - perhaps snakeoiled?)
But even so, there are ways to use certbot in such a situation.
You could use --webroot -w /path/to/{new-site-name}
and explicitly define the cert name used to match with --cert-name {new-site-name}
which could fit nicely into a well defined scripted implementation.
I ended up using lua-resty-auto-ssl works very nicely
