Could not renew certificates
conference.iai.int
./certbot-auto --force-renewal
Certbot doesn’t know how to automatically configure the web server on this system.
latest nginx
Ubuntu Server 16.04
I’ve tried also certbot-only renew …see the results:
Requesting root privileges to run certbot…
/home/deploy/.local/share/letsencrypt/bin/letsencrypt renew
Processing /etc/letsencrypt/renewal/conference.iai.int.conf
Cert not yet due for renewal
/etc/letsencrypt/live/conference.iai.int/fullchain.pem (skipped)
No renewals were attempted.
deploy@ubunturuby:~$ ./certbot-auto renew
It says not due for renewal, but I can’t access the site due too expired certificates. ???
@AlejandroF, it could be that your originally obtained the certificate with certonly, in which case Certbot didn’t install it for you, and also won’t handle restarting the web server upon renewal. This is actually rather likely since you’re using nginx and got your certificate a while ago; forms with certbot certonly --webroot were usually recommended for nginx users at that point.
You do have a renewed, currently-valid certificate for your domain already
https://crt.sh/?id=138693393
so there should be no need to renew it right now. However, your server is currently not using that certificate. Getting it to use it could be as simple as restarting nginx.
I just checked and it looks like you’ve already resolved the problem on your own.
If the problem turned out to be just about needing to restart nginx, you can do something like certbot-auto renew --renew-hook "service nginx graceful" in crontab, to tell Certbot to reload nginx for you if a renewal happens.
I did. I’m like a dog with a bone when I have problems… will not let go until I solve it.
Thanks anyway!Alejandro
Will do. This was unknown to me.
Alejandro
