secweb.me
I am using ACME
I am trying to make DNS method work but it will not work.
I do not understand what I need to do here
secweb.me
I am using ACME
If you run phpinfo(): Does "Openssl default config" point to a valid Openssl config file?
Ok, but which ACME v2 client?
And which version?
Here is a list ACME Client Implementations - Let's Encrypt, likely not exhaustive.
What are you using the Domain Validated (DV) Certificate for?
I am guessing to server Port 443 HTTPS web services.
I am guessing your Operating System is Windows, which version?
