Could not issue certificate using certbot, authorization error
My domain is: similarity.example.com
sudo /usr/bin/certbot --nginx -d similarity.example.net
Failed authorization procedure. similarity.example.net (http-01): urn:ietf:params:acme:error:connection ::
The server could not connect to the client to verify the domain :: 40.121.xx.xxx: Fetching http://similarity.example.net/.well-known/acme-challenge/FgDPN2axu9-fKa5eeB-FBoHKZw-3fzSgLzN1jPcMOrA: Timeout during connect (likely firewall problem)
nginx/1.20.1
Ubuntu 20.0.4
My hosting provider, if applicable, is: azure cloud
certbot 0.31.0
It's probably a firewall issue, or nginx isn't starting.
We can't run any diagnostics if you don't tell us the actual domain name.
No, it isn't. As the question template says, we need your real domain name in order to help you.
This error message seems pretty clear: Let's Encrypt's validation servers were unable to connect to your server. Fix whatever's in the way of that connection and try again.
i have updated the question with the actual domain,
Regarding firewall, firewall is completely inactive, even though when i activate it, issue could not be resolved
sudo ufw status
Status: inactive
sudo ufw enable
Command may disrupt existing ssh connections. Proceed with operation (y|n)? y
Firewall is active and enabled on system startup
 sudo ufw status
\Status: active
To                         Action      From
80                         ALLOW       Anywhere
443                        ALLOW       Anywhere
8069                       ALLOW       Anywhere
80 (v6)                    ALLOW       Anywhere (v6)
443 (v6)                   ALLOW       Anywhere (v6)
8069 (v6)                  ALLOW       Anywhere (v6)
Either something's blocking that connection, or nginx isn't running. One way or the other, HTTP connections are failing. See:
...and I'm seeing the same issue when I try to connect from my browser.
I see 443 as closed, no 80, no 8069. Just 22 answers.
Check if there's another firewall, in the azure console probably.
i have recalled that security group in amazon cloud after 1 day of investigation, port 80 was not opened in cloud firewall
