Could not issue an SSL/TLS certificate for my domain - Plesk w/ VULTR and my domain is w/ Namecheap
I am using Plesk w/ VULTR and my domain is w/ Namecheap
Here are the steps that I did :
→ Websites & Domains then
→ Security then
→ SSL/TLS Certificates the
→ Install Let's Encrypt DV certificate for my SSL/TLS Certificate for my domain
I get this error
Could not issue a Let's Encrypt SSL/TLS certificate for (mydomain). Authorization for the domain failed.
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/8723320368.
Details:
Type: urn:ietf:params:acme:error:connection
Status: 400
Detail: Fetching http://mydomain.com/.well-known/acme-challenge/RoPgDgKWlfdyoTUnbXKvmw_foR61cpFJF1uwBuSQp50: Timeout during connect (likely firewall problem)
→ Can you please guide me the step by step way to fix this? I am new w/ Plesk and I am having a hard time fixing this
Hi @avlza
that url
http://arnievlz.com/.well-known/acme-challenge/RoPgDgKWlfdyoTUnbXKvmw_foR61cpFJF1uwBuSQp50
doesn't answer, there is a timeout.
A working port 80 is required if you want to create a certificate via http validation.
I will update the port via plesk?
Could not issue an SSL/TLS certificate for arnievlz.com
Details
Could not issue a Let's Encrypt SSL/TLS certificate for arnievlz.com. Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/8723817757.
Details:
Status: 400
Detail: Fetching http://arnievlz.com/.well-known/acme-challenge/dejA8EdXRDVClV3fbqcSivf9GakUwhFPD7nOvNB8Pkw: Timeout during connect (likely firewall problem)
Welcome to the Let's Encrypt Community :slightly_smiling_face:
Your webserver is currently non-responsive over port 80 http (as well as port 443 https). You need a functioning webserver that either responds to requests over port 80 or forwards those requests for response.
Did you shutdown your webserver for some reason?
