Could not choose appropriate plugin: The requested nginx plugin does not appear to be installed
kingbiscuitblues.com
sudo certbot renew --nginx
ubuntu
Did you install python-certbot-nginx?
No, it wasn’t installed but I installed it now sudo certbot renew --nginx returns this error
None of the preferred challenges are supported by the selected plugin. Skipping.
I didn’t pass in preferred-challenges because my understanding was that it’s only for use with the --manual option and also since I’m using wildcard domains I’m forced to use the default challenge dns01
Hi @fugee
please read some basics:
If you want to create a wildcard certificate, you have to use the dns challenge. So you can't use nginx as authenticator.
What does that mean nginx as authenticator? What’s the difference between dns and dns01 and which is for use with wildcards
Does anyone know what he means? Is it me or is it him? It’s him right?
https://certbot.eff.org/docs/using.html#getting-certificates-and-choosing-plugins
Since the nginx plugin doesn't support DNS validation, you can't use it to get a wildcard certificate.
You could probably use -i nginx to install a wildcard certificate, though.
There isn't currently a difference between "dns" and "dns-01". If a DNS-02 challenge type is ever invented, maybe the Certbot developers would change the meaning of "dns", but they're equivalent now.
Thanks And if I can’t use the nginx plugin I can’t use what certbot commands?
Do you really need a wildcard certificate?
Your domain is currently using Namecheap's DNS service. It can be automated with an API, but it's not available to all customers, and Certbot doesn't include support for it. (At least one other ACME client does.)
https://www.namecheap.com/support/knowledgebase/article.aspx/9739/63/api--faq#c
Can you use a non-wildcard certificate? Remember that it's not hard to get Let's Encrypt certificates covering hundreds or thousands of subdomains.
If you do need a wildcard certificate, do you qualify to use Namecheap's API?
If not, can you switch to a different DNS service? Particularly one supported by Certbot?
Can you answer the other questions from the first post?
nginx 1.14.0 if that helps
