Authentication problem on certificate creation
My domain is: shuttlefinder.app
I ran this command: sudo certbot --nginx -d shuttlefinder.app -d *.shuttlefinder.app
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA. You may need to use an authenticator plugin that can do challenges over DNS.
My web server is (include version): nginx/1.10.3 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 16.04.5 LTS
My hosting provider, if applicable, is: DigitalOcean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Hi @matthiasunt
if you want to create a wildcard certificate, you have to use dns-01 validation.
So check, if you can use --dns-digitalocean
https://certbot.eff.org/docs/using.html
as plugin.
If not, you have to use --manual.
