Correct permisions for /etc/letsencrypt so apache2 can read cert
certbot certonly --manual --preferred-challenges=dns --email dev.accounts@kitchencut.com --server https://acme-v02.api.letsencrypt.org/directory --agree-tos -d notsharingdomain.com
Certificate is saved at: /etc/letsencrypt/live/notsharingdomain.com/fullchain.pem
Key is saved at: /etc/letsencrypt/live/notsharingdomain.com/privkey.pem
This certificate expires on 2024-07-10.
My web server is apache 2.4
The operating system my web server runs on is ubuntu 22.04
The version of my client is: certbot 1.21.0Certbot):
I see this asked a lot, but from what i see people just lessen the security on the /etc/letsecrypt directory that is is wide open.
My question is, what does the certbot installer do that I can do manually so Apache can actually read the certs without breaking the permissions ? I have a large amount of sub domains so it would make sense to use a wildcard cert. I could use chmod 755 or 775 but that might not be the best practice.
There is very little information when you do it manually instead of auto. And like i said some of the things people do like chmod 777 just scares me.
I'm sorry, but I fail to notice the reason WHY you want to manually mess with the permissions? Especially when using Apache, there should be nothing to do with regard to the permissions: it should work just fine.
Sorry I forgot to mention:
AH00526: Syntax error on line 38 of /etc/apache2/sites-enabled/console01-beta.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/notsharingdomain.com/fullchain.pem;' does not exist or is empty
Action 'configtest' failed.
That is why I am asking. The cert is legit and not empty. Confirmed with openssl x509 -text -noout -in /etc/letsencrypt/live/notsharingdomain.com/fullchain.pem
Never mind. Was a typo. I was working with nginx earlier and when i pasted the links to the certs i added ';' at the end. sorted - nothing wrong. my apologies
