Connection Timeout with ACME Challenge
My knowledge of LE is pretty low so sorry in advance if it looks like something straight forward to fix :). I’m currently trying to implement a single certificate issue for one of my testing domains via ACME Challenge. My main goal is to import that certificate on an ALB and let it manage the HTTPS for my websites. My current setup is :
1 Application Load Balancer (AWS) that manage the domain certificate.mydomain.com (which I’m trying to create a certificate for). This load balancer shares load between 2 targets, which are HA Proxies. Those HA Proxies relay traffic to 2 different apache servers. The HA Proxies don’t have any “fancy” configs, only that if the main server goes down, traffic gets to the backup apache server. Both apache web servers have a proxypass rule to relay traffic /.well-known/acme-challenge to the certificate server
(ProxyPass /.well-known/acme-challenge http://validation-server.mydomain.com/.well-known/acme-challenge/)
1 certificate server configured to handle acme-challenges (and where I will generate the certificates). Again, nothing fancy here, only configuration for the webroot (yes it’s require all granted, gonna lock it up as soon as I have a working setup)
AliasMatch ^/.well-known/acme-challenge/(.*)$ /var/www/html/.well-known/acme-challenge/$1
<Directory “/var/www/html/.well-known/acme-challenge/”>
Options None
AllowOverride None
ForceType text/plain
Require all granted
The command I currently use to try to request a certificate is the following
certbot-auto certonly --test-cert --webroot -w /var/www/html/ -d certificate.mydomain.com
And the output
http-01 challenge for certificate.lexum.com
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
Failed authorization procedure. certificate.mydomain.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://certificate.mydomain.com/.well-known/acme-challenge/tv8GqsnY7vx5wEFSxbjbYyt7aGCBXerLO9M3kOxfJjE: Timeout
    Domain: certificate.mydomain.com
    Type: connection
    Detail: Fetching
    Timeout
Fun fact is, in the apache logs, I see 200’s requests like this while running the above command.
“GET /.well-known/acme-challenge//tv8GqsnY7vx5wEFSxbjbYyt7aGCBXerLO9M3kOxfJjE HTTP/1.1” 200 87 “-” “Mozilla/5.0 (compatible; Let’s Encrypt validation server; +https://www.letsencrypt.org)”
Why then the timeout connection? I’m kinda confused about that part.
Hopefully there’s enough infos, if not feel free to ask.
Thanks!
KP
Okay… for an unknown reason, it works now. I know I changed DNS on my end (for certificate.mydomain.com), but it was a while back this morning.
I guess I’m good now :slight_smile:
Thanks!
KP
