Issue or renew a cert : timeout (certbot and acme.sh) [ solved]
Last june I was able to issue a certificate with certbot, but it is impossible to renew it.
I have the same problem when trying to issue a new certificate for an other domain.
I tried certbot and acme.sh.
The result is always the same :
I have set up rules in our firewall to allow traffic between the server and acme-v02.api.letsencrypt.org.
There is outgoing traffic, but nothing comes back, which means that we don't get an answer from letsencrypt.org.
With certbot the challenge is not created on the server, but with acme.sh it is, and is accessible from outside
my domains are : glpi-test.ehess.fr, vintest-cas.ehess.fr
the commands :
certbot certonly --apache -d vintest-cas.ehess.fr [-v]
acme.sh --issue -d glpi-test.ehess.fr -w /srv/www/htdocs/dummy --server letsencrypt [--debug]
The operating system my web server runs on is : openSUSE Leap 15.3, Apache 2.4.51
We are self-hosted
I can login to a root shell on my machine.
The version of my client is :
certbot 1.30.0
acme.sh 3.0.5
certbot output :
certbot certonly --apache -d vintest-cas.ehess.fr -v
ssl_module is statically linked but --apache-bin is missing; not disabling session tickets.
Requesting a certificate for vintest-cas.ehess.fr
http-01 challenge for vintest-cas.ehess.fr
Challenge failed for domain vintest-cas.ehess.fr
Domain: vintest-cas.ehess.fr
Type: connection
Detail: 193.48.45.225: Fetching http://vintest-cas.ehess.fr/.well-known/acme-challenge/gwCaPM1oCzS3qvAehvbTQJEg52yAlJWZw5OIx_X4e4E: Timeout during connect (likely firewall problem)
acme.sh output :
[lun. oct. 3 15:17:18 CEST 2022] Using CA: https://acme-v02.api.letsencrypt.org/directory
[lun. oct. 3 15:17:18 CEST 2022] Single domain='glpi-test.ehess.fr'
[lun. oct. 3 15:17:18 CEST 2022] Getting domain auth token for each domain
[lun. oct. 3 15:17:20 CEST 2022] Getting webroot for domain='glpi-test.ehess.fr'
[lun. oct. 3 15:17:20 CEST 2022] Verifying: glpi-test.ehess.fr
[lun. oct. 3 15:17:21 CEST 2022] Pending, The CA is processing your order, please just wait. (1/30)
[lun. oct. 3 15:17:24 CEST 2022] Pending, The CA is processing your order, please just wait. (2/30)
[lun. oct. 3 15:17:28 CEST 2022] Pending, The CA is processing your order, please just wait. (3/30)
[lun. oct. 3 15:17:31 CEST 2022] Pending, The CA is processing your order, please just wait. (4/30)
[lun. oct. 3 15:17:35 CEST 2022] glpi-test.ehess.fr:Verify error:193.48.45.166: Fetching http://glpi-test.ehess.fr/.well-known/acme-challenge/pZ3NT6-LJqGRPV9pnf6EtZUzqYO-W4nb_B_8L1HCwIg: Timeout during connec)
[lun. oct. 3 15:17:35 CEST 2022] Please add '--debug' or '--log' to check more details.
[lun. oct. 3 15:17:35 CEST 2022] See: How to debug acme.sh · acmesh-official/acme.sh Wiki · GitHub
thank you for your help
Please open port 80 and please keep it open :slight_smile:
Hi Osiris.
Thank your for your answer.
There is a time-limit in our firewall access-lists for the 2 servers, I did not see it before ...
Port 80 is now open.
There is another problem : CAA record for xxx prevents issuance.
I will investigate.
Thanks for your help
edit : the DNS CAA record for lestencrypt in our DNS configuration was commented
