I encountered the "Connection reset by peer" problem. I used WireShark to capture packets. I found that the connection was established correctly, but after my server completed the response, the Let's Encrypt server sent an RST to reset the connection, causing the connection to fail.
Subsequently, Let's Encrypt initiated another request from a different IP address, but this time the request was shorter. Before my server sent a response, it received an RST.
Hi @tianxiadys, and welcome to the LE community forum ![]()
Please show the logfile:
/var/log/letsencrypt/letsencrypt.log
1.pcap (80.9 KB)
letsencrypt.log.txt (57.1 KB)
I'm seeing:
for all HTTP connections to your site.
You may be capturing packets on the wrong side of the firewall.
You are right, but that may be because my server was not listening on port 80. Now I have started nginx to listen to it. Please try again.
They changed to:
curl: (52) Empty reply from server
ohhhhh, my server is in Beijing. This may be a network issue unique to mainland China. Maybe it will resolve itself in a few days.
Those replies might contain the Let's Encrypt IP addresses, but that doesn't necessarily mean they actualle came from LE.
hint: There may be a great firewall involved...
Check that you don't have any geographic or IP range filtering on incoming connections either on your own server or your router/firewall. Something on your side is closing the connection.
Chinese hosting providers sometimes also enforce the ICP license by blocking connections to a server until they're satisfied that it is licensed to operate a public service.
Thank you for all the replies. Specifically, my server is purchased from Alibaba Cloud and located in Beijing, and I have already obtained an ICP license. I am seeking help from Alibaba Cloud, but they also do not seem to have any effective solutions. Here is a global connectivity test showing that access to any servers located outside of China are reset.
The thing that's failing is when Let's Encrypt tries to validate your domain using http, so if that is outside your control you could instead validate your domain using DNS.
