Connection reset by peer Error
I’m trying to configure on my server, I have full access to ir and my domain is correctly published and responding to my own IP.
My domain is: ajsantos.com.br
I ran this command: certbot --apache
It produced this output: Waiting for verification…
Challenge failed for domain ajsantos.com.br
http-01 challenge for ajsantos.com.br
    Domain: ajsantos.com.br
    Type: connection
    Detail: Fetching
    http://ajsantos.com.br/.well-known/acme-challenge/-50uqRD-0DEFAFge9rbSFa37bGM68rkHb4kFhBUwcEY:
My web server is (include version): Apache/2.4.6 (CentOS)
The operating system my web server runs on is (include version): CentOS Linux 7
My hosting provider, if applicable, is: Embratel/Claro Brazil
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.6.0
Hi @lucioacsantos
there is a check of your domain, some hours old - https://check-your-website.server-daten.de/?q=ajsantos.com.br
http and http + /.well-known/acme-challenge/random-filename works, the expected result http status 404 - Not Found.
So if Letsencrypt has that "Connection reset by peer" error, you may have a blocking firewall or something else. May be a regional filter.
I have tried using the --manual parameter, certbot run -a manual -i apache -d ajsantos.com.br -d www.ajsantos.com.br, but had the same error while trying to connect.
Type: connection
Detail: Fetching
http://ajsantos.com.br/.well-known/acme-challenge/Kf1gDlRcER36pADA57Xpr3JJk_VDgTdE4d1WbfW92Vc:
This URL is fully accessible by browser or CURL on my local computer, my firewall is disabled and I don’t have others security rules.
How may I solve this problem?
You have something. Find that and remove it.
I have checked again, there is no security rules on my server.
I got this log in the access_log from httpd:
3.14.255.131 - - [25/Jul/2020:16:58:03 -0300] “GET /.well-known/acme-challenge/axWZ6_cG_V5hSKF6BOo2J2hwCYoKnxh8d9kl6bTIbQs HTTP/1.1” 200 87 “-” “Mozilla/5.0 (compatible; Let’s Encrypt validation server; +https://www.letsencrypt.org)”
34.222.229.130 - - [25/Jul/2020:16:58:03 -0300] “GET /.well-known/acme-challenge/axWZ6_cG_V5hSKF6BOo2J2hwCYoKnxh8d9kl6bTIbQs HTTP/1.1” 200 87 “-” “Mozilla/5.0 (compatible; Let’s Encrypt validation server; +https://www.letsencrypt.org)”
52.28.236.88 - - [25/Jul/2020:16:58:03 -0300] “GET /.well-known/acme-challenge/axWZ6_cG_V5hSKF6BOo2J2hwCYoKnxh8d9kl6bTIbQs HTTP/1.1” 200 87 “-” “Mozilla/5.0 (compatible; Let’s Encrypt validation server; +https://www.letsencrypt.org)”
The system has a code 200 on this log, there is a valid connection but still with the same error.
Checked an own log to find the check of my last certificate:
4 checks per domain name, not 3.
Looks like you block one.
Solved by installing VestaCP control panel and activating support SSL Let’s Encrypt on it. Thanks by your help!
