I'm trying to update the SSL of a hosting site using Certbot installed on a Windows computer. Previously, this worked several times, but now during validation it gives the error “Connection reset by peer”.
Similar errors occur when trying to validate all hosting sites. Validation also fails when receiving free SSL on sites like https://sslforweb.com/
Hosting support says:
No restrictions were found on the hosting side.
In this case, I can suggest contacting certbot support.
docs.module-electronic.ru
certbot certonly --manual
Domain: docs.module-electronic.ru
Type: connection
Detail: 91.189.114.19: Fetching http://docs.module-electronic.ru/.well-known/acme-challenge/oLYffjvaxrMDy599VOIg679X-p-vsZq_LiBGcvyPK68: Connection reset by peer
Hint: The Certificate Authority failed to verify the manually created challenge files. Ensure that you created these in the correct location.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.log or re-run Certbot with -v for more details.
Apache/2.4.56 (Red Hat Enterprise Linux 8) PHP/7.4.33
Linux 6.2.10-1.el8.x86_64
RU-CENTER
ISPmanager 6
certbot 1.17.0
In Certbot log file:
2023-11-05 16:08:31,455:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\docs.module-electronic.ru-0001.conf is broken. Skipping.
2023-11-05 16:08:31,657:DEBUG:certbot._internal.cert_manager:Traceback was:
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\cert_manager.py", line 408, in _search_lineages
candidate_lineage = storage.RenewableCert(renewal_file, cli_config)
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\storage.py", line 473, in __init__
self._check_symlinks()
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\storage.py", line 543, in _check_symlinks
raise errors.CertStorageError(
certbot.errors.CertStorageError: expected C:\Certbot\live\docs.module-electronic.ru-0001\cert.pem to be a symlink
2023-11-05 16:08:31,669:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\docs.module-electronic.ru-0002.conf is broken. Skipping.
2023-11-05 16:08:31,669:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\docs.module-electronic.ru-0002\cert.pem to be a symlink
2023-11-05 16:08:31,685:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\docs.module-electronic.ru-0003.conf is broken. Skipping.
2023-11-05 16:08:31,685:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\docs.module-electronic.ru-0003\cert.pem to be a symlink
2023-11-05 16:08:31,695:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\docs.module-electronic.ru-0004.conf is broken. Skipping.
2023-11-05 16:08:31,696:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\docs.module-electronic.ru-0004\cert.pem to be a symlink
2023-11-05 16:08:31,709:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\docs.module-electronic.ru.conf is broken. Skipping.
2023-11-05 16:08:31,710:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\docs.module-electronic.ru\cert.pem to be a symlink
2023-11-05 16:08:31,724:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\module-electronic.ru-0001.conf is broken. Skipping.
2023-11-05 16:08:31,724:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\module-electronic.ru-0001\cert.pem to be a symlink
2023-11-05 16:08:31,737:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\module-electronic.ru.conf is broken. Skipping.
2023-11-05 16:08:31,737:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\module-electronic.ru\cert.pem to be a symlink
2023-11-05 16:08:31,747:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\new.module-electronic.ru-0001.conf is broken. Skipping.
2023-11-05 16:08:31,748:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\new.module-electronic.ru-0001\cert.pem to be a symlink
2023-11-05 16:08:31,760:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\new.module-electronic.ru-0002.conf is broken. Skipping.
2023-11-05 16:08:31,760:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\new.module-electronic.ru-0002\cert.pem to be a symlink
2023-11-05 16:08:31,774:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\new.module-electronic.ru-0003.conf is broken. Skipping.
2023-11-05 16:08:31,775:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\new.module-electronic.ru-0003\cert.pem to be a symlink
2023-11-05 16:08:31,782:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\new.module-electronic.ru-0004.conf is broken. Skipping.
2023-11-05 16:08:31,783:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\new.module-electronic.ru-0004\cert.pem to be a symlink
2023-11-05 16:08:31,793:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\new.module-electronic.ru-0005.conf is broken. Skipping.
2023-11-05 16:08:31,794:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\new.module-electronic.ru-0005\cert.pem to be a symlink
2023-11-05 16:08:31,803:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\new.module-electronic.ru.conf is broken. Skipping.
2023-11-05 16:08:31,803:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\new.module-electronic.ru\cert.pem to be a symlink
2023-11-05 16:08:31,814:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\nikaeng.ru-0001.conf is broken. Skipping.
2023-11-05 16:08:31,815:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\nikaeng.ru-0001\cert.pem to be a symlink
2023-11-05 16:08:31,826:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\nikaeng.ru-0002.conf is broken. Skipping.
2023-11-05 16:08:31,826:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\nikaeng.ru-0002\cert.pem to be a symlink
2023-11-05 16:08:31,835:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\nikaeng.ru-0003.conf is broken. Skipping.
2023-11-05 16:08:31,836:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\nikaeng.ru-0003\cert.pem to be a symlink
2023-11-05 16:08:31,847:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\nikaeng.ru-0004.conf is broken. Skipping.
2023-11-05 16:08:31,847:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\nikaeng.ru-0004\cert.pem to be a symlink
2023-11-05 16:08:31,860:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\nikaeng.ru.conf is broken. Skipping.
2023-11-05 16:08:31,860:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\nikaeng.ru\cert.pem to be a symlink
2023-11-05 16:08:31,870:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\old.module-electronic.ru-0001.conf is broken. Skipping.
2023-11-05 16:08:31,870:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\old.module-electronic.ru-0001\cert.pem to be a symlink
2023-11-05 16:08:31,879:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\old.module-electronic.ru-0002.conf is broken. Skipping.
2023-11-05 16:08:31,879:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\old.module-electronic.ru-0002\cert.pem to be a symlink
2023-11-05 16:08:31,892:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\old.module-electronic.ru-0003.conf is broken. Skipping.
2023-11-05 16:08:31,892:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\old.module-electronic.ru-0003\cert.pem to be a symlink
2023-11-05 16:08:31,902:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\old.module-electronic.ru-0004.conf is broken. Skipping.
2023-11-05 16:08:31,902:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\old.module-electronic.ru-0004\cert.pem to be a symlink
2023-11-05 16:08:31,912:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\old.module-electronic.ru.conf is broken. Skipping.
2023-11-05 16:08:31,912:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\old.module-electronic.ru\cert.pem to be a symlink
2023-11-05 16:08:31,923:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\smart.module-electronic.ru-0001.conf is broken. Skipping.
2023-11-05 16:08:31,923:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\smart.module-electronic.ru-0001\cert.pem to be a symlink
2023-11-05 16:08:31,934:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\smart.module-electronic.ru-0002.conf is broken. Skipping.
2023-11-05 16:08:31,934:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\smart.module-electronic.ru-0002\cert.pem to be a symlink
2023-11-05 16:08:31,944:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\smart.module-electronic.ru-0003.conf is broken. Skipping.
2023-11-05 16:08:31,945:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\smart.module-electronic.ru-0003\cert.pem to be a symlink
2023-11-05 16:08:31,955:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\smart.module-electronic.ru-0004.conf is broken. Skipping.
2023-11-05 16:08:31,955:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\smart.module-electronic.ru-0004\cert.pem to be a symlink
2023-11-05 16:08:31,965:DEBUG:certbot._internal.cert_manager:Renewal conf file C:\Certbot\renewal\smart.module-electronic.ru.conf is broken. Skipping.
2023-11-05 16:08:31,965:DEBUG:certbot._internal.cert_manager:Traceback was:
certbot.errors.CertStorageError: expected C:\Certbot\live\smart.module-electronic.ru\cert.pem to be a symlink
2023-11-05 16:08:31,968:DEBUG:certbot.display.util:Notifying user: Requesting a certificate for docs.module-electronic.ru
2023-11-05 16:08:32,358:DEBUG:certbot.crypto_util:Generating RSA key (2048 bits): C:\Certbot\keys\0063_key-certbot.pem
2023-11-05 16:08:32,454:DEBUG:certbot.crypto_util:Creating CSR: C:\Certbot\csr\0063_csr-certbot.pem
2023-11-05 16:08:32,456:DEBUG:acme.client:Requesting fresh nonce
2023-11-05 16:08:32,456:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2023-11-05 16:08:32,466:DEBUG:urllib3.connectionpool:Resetting dropped connection: acme-v02.api.letsencrypt.org
2023-11-05 16:08:32,990:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2023-11-05 16:08:32,994:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 05 Nov 2023 13:08:33 GMT
Replay-Nonce: M1qVDtAvHERUr_oBR1OzgfhwC9GCzIO7FFCSlOBPq67YkiZeABs
X-Frame-Options: DENY
2023-11-05 16:08:32,995:DEBUG:acme.client:Storing nonce: M1qVDtAvHERUr_oBR1OzgfhwC9GCzIO7FFCSlOBPq67YkiZeABs
2023-11-05 16:08:32,996:DEBUG:acme.client:JWS payload:
b'{\n "identifiers": [\n {\n "type": "dns",\n "value": "docs.module-electronic.ru"\n }\n ]\n}'
2023-11-05 16:08:33,014:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTMwMzkyODExIiwgIm5vbmNlIjogIk0xcVZEdEF2SEVSVXJfb0JSMU96Z2Zod0M5R0N6SU83RkZDU2xPQlBxNjdZa2laZUFCcyIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvbmV3LW9yZGVyIn0",
"signature": "UbLs0tvw-R-9i5AZhWHow15dSkj5WQkahHZDD8WkKMOgOqA1sAb9cQf8b5QuzWwJWx49ctHRMn7RiFT114hgbkF-rK-hTN-HrOfxp3BMDbd3fNQHqPfDElKo75GSKjznjBmVR3Dgi16d5i9vQlC0nBJ7eWzdli4ldLFu0xg7z0I4mhGAYrWZZ2MKO4bIsMzDcszSIZ7R09NXCcYsEFtMWTyigoZJcdyTvwkZxJwE6FQMIMykcEkG_Zl5mTNzbjg0KyWMRkfJdYQhz_Kym0zzc6utm5fF0eV9JFLGMBa_VtDYaC8pyBFO5l3gxbrmEfWCWCR7CeajZoGS3V3jiL7OWA",
"payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogImRvY3MubW9kdWxlLWVsZWN0cm9uaWMucnUiCiAgICB9CiAgXQp9"
2023-11-05 16:08:33,318:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 350
2023-11-05 16:08:33,320:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 350
Boulder-Requester: 130392811
Location: https://acme-v02.api.letsencrypt.org/acme/order/130392811/220061349586
Replay-Nonce: M1qVDtAvnB14t_Y_LrMF0GUHfcmvPBsbxvsys3Fjez336qp6ItI
"status": "pending",
"expires": "2023-11-12T13:08:33Z",
"identifiers": [
"type": "dns",
"authorizations": [
"https://acme-v02.api.letsencrypt.org/acme/authz-v3/280836488786"
"finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/130392811/220061349586"
2023-11-05 16:08:33,320:DEBUG:acme.client:Storing nonce: M1qVDtAvnB14t_Y_LrMF0GUHfcmvPBsbxvsys3Fjez336qp6ItI
2023-11-05 16:08:33,321:DEBUG:acme.client:JWS payload:
b''
2023-11-05 16:08:33,334:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/280836488786:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTMwMzkyODExIiwgIm5vbmNlIjogIk0xcVZEdEF2bkIxNHRfWV9Mck1GMEdVSGZjbXZQQnNieHZzeXMzRmplejMzNnFwNkl0SSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYXV0aHotdjMvMjgwODM2NDg4Nzg2In0",
"signature": "u-AwIvgnT0L3MeEp8jre8rXVT2NqHA28Kzxjchswe9SFqIKMf-TIa4w2g_8jKHcYqKgSgRkuka83PIu_YVVUWpGRgBltJGdBpnCVubh4QkWuFOH2hPqXpGs_jjYp0SkQVt1LCctR1eaD1JLl-CCru-LniezBvk-OIgIVkQ7KdUZHW_8Nv9M2aZsh9Cm-q-0xs8Avnpq9K1xVcV8DElbo5LRJyJBhgLq8mlEZHGHf6ROT08L0cCgf5eyfdCVPsQeSQVtZ3nWwmc-eUEjj-tEGEVtw1Mf3z4OlWa-Ho-_qo2K3eNNi85f52qmtxgLsTcT3d0F_E4FxEZNt4ltINWxyfg",
"payload": ""
2023-11-05 16:08:33,496:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/280836488786 HTTP/1.1" 200 809
2023-11-05 16:08:33,497:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 809
Replay-Nonce: M1qVDtAvkaz4NJhze6sKzkCTuM4H2dlPdxdK1QGvWJc3YOt_yVo
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/280836488786/yujXiw",
"token": "oLYffjvaxrMDy599VOIg679X-p-vsZq_LiBGcvyPK68"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/280836488786/GsQj3w",
"type": "tls-alpn-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/280836488786/1i3pgQ",
2023-11-05 16:08:33,498:DEBUG:acme.client:Storing nonce: M1qVDtAvkaz4NJhze6sKzkCTuM4H2dlPdxdK1QGvWJc3YOt_yVo
2023-11-05 16:08:33,499:INFO:certbot._internal.auth_handler:Performing the following challenges:
2023-11-05 16:08:33,501:INFO:certbot._internal.auth_handler:http-01 challenge for docs.module-electronic.ru
2023-11-05 16:08:33,503:DEBUG:certbot.display.util:Notifying user: Create a file containing just this data:
oLYffjvaxrMDy599VOIg679X-p-vsZq_LiBGcvyPK68.q5yYvnADL0gKeUyvb0PEw6pR_uEq7t76oFkJH1cx3zs
2023-11-05 16:10:54,801:DEBUG:acme.client:JWS payload:
b'{}'
2023-11-05 16:10:54,813:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/280836488786/yujXiw:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTMwMzkyODExIiwgIm5vbmNlIjogIk0xcVZEdEF2a2F6NE5KaHplNnNLemtDVHVNNEgyZGxQZHhkSzFRR3ZXSmMzWU90X3lWbyIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvY2hhbGwtdjMvMjgwODM2NDg4Nzg2L3l1alhpdyJ9",
"signature": "rGOeEVYW4_YwMrH-G_iOC97OZEGuPLScJCLdYi9f1OgfurHHzM5y-elr3n97Z4lCFaaWPY0MPzM5Hu-Bii-kq5wybupX7OAu28bN-f_MLJ4DCmlgm2S6vbe28O4Ci_zCeqq-lpsqs06Y7Q3Qh5Iu69GPSYcQAuwWPCytYCfoQNGp3pM119ZxEpYLTX3ZjLF4AUsmJAo_KvhDfQm-rZB8cmA02gKjpbabJOUFDe_CiCX6qlatZHSbPrG1HJ6dXEDmOpadgG9T2Psmv5be4lnarnYw2BaVCWXKQWd7KcgBC7Xw_PPlGbQC3i-xvf46eeiC4pEEcV10QG8tUs5DG03MxQ",
"payload": "e30"
2023-11-05 16:10:54,977:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/280836488786/yujXiw HTTP/1.1" 200 187
2023-11-05 16:10:54,979:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 05 Nov 2023 13:10:55 GMT
Content-Length: 187
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-v02.api.letsencrypt.org/acme/authz-v3/280836488786>;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/280836488786/yujXiw
Replay-Nonce: mEGmtpGSq9-Pop2TgP164ONo72WlUjH4DYQWBp0x8bR___M7CpE
"type": "http-01",
2023-11-05 16:10:54,980:DEBUG:acme.client:Storing nonce: mEGmtpGSq9-Pop2TgP164ONo72WlUjH4DYQWBp0x8bR___M7CpE
2023-11-05 16:10:54,982:INFO:certbot._internal.auth_handler:Waiting for verification...
2023-11-05 16:10:55,990:DEBUG:acme.client:JWS payload:
b''
2023-11-05 16:10:55,998:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/280836488786:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTMwMzkyODExIiwgIm5vbmNlIjogIm1FR210cEdTcTktUG9wMlRnUDE2NE9ObzcyV2xVakg0RFlRV0JwMHg4YlJfX19NN0NwRSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYXV0aHotdjMvMjgwODM2NDg4Nzg2In0",
"signature": "CdBbFwgLWPGcRds2JY8RlcffSrtguO2k-7W-j24M1ZnvoDUOtfTnX18GyCX6X2clJbQ02uDYAfAHzPsUd8gYI_bZ6dm_aWSnJ5Kgv948I0rpBHI37_XorThFTcay87hePKIxJ-YwzzRJAKEiPmxvktZUFxXafYy9nLYCq_J26W1YbGB2G3Ar8oBgIu2Rgwk6ZirasW6gydfG1cGssEshcGUtLDUAtxhkTqjRIkYty-v66lcTzGOwzeiYZ695Kqa3EQVKxgfFzNt4a3Qpni82f6rri8Da11P1OFQZ6NVSe4Z8qcoT_9oz4b_1MQiBR1b9SbGZf7DjqV3fXBYNepVL2w",
"payload": ""
2023-11-05 16:10:56,161:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/280836488786 HTTP/1.1" 200 809
2023-11-05 16:10:56,164:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 05 Nov 2023 13:10:56 GMT
Content-Length: 809
Replay-Nonce: mEGmtpGSQRR-uZQD7pQuBZ5JZnWVaYA0WmSHaCHLl3NyDlF_E94
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"type": "dns-01",
2023-11-05 16:10:56,165:DEBUG:acme.client:Storing nonce: mEGmtpGSQRR-uZQD7pQuBZ5JZnWVaYA0WmSHaCHLl3NyDlF_E94
2023-11-05 16:10:59,173:DEBUG:acme.client:JWS payload:
b''
2023-11-05 16:10:59,190:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/280836488786:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTMwMzkyODExIiwgIm5vbmNlIjogIm1FR210cEdTUVJSLXVaUUQ3cFF1Qlo1SlpuV1ZhWUEwV21TSGFDSExsM055RGxGX0U5NCIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYXV0aHotdjMvMjgwODM2NDg4Nzg2In0",
"signature": "MTpKnHB7id0rBjdMkiFQ35-Vg90vAJt9x9OssMEx0QLh_vHiuDLtQ6FQoARYw-zTlKasYP3a5V2bT9Y-EeJoa0q0iOmn8cYFtkEmMzqqSXpUVI2G11qStT1mlD4UK35BfPomEHV5e35Q72_EAMjkhMs-b4RMCCc_EJlkrhSEYwfUW62325CvE0XTl8aWKfKnKg6hhXrVTZtdebPYdZlDGxAIZ-jzrnVXVCDwbAil4w30TS-OHd2lBDJOIVDGUN0l06giplzoKvWN1rH7Xl_fNHFH4JEbP-rGs68_aPTDE0_ZDb3tV0og3lCbWCGRBwf-NH1uBSKOMKWq529OTPI9ZQ",
"payload": ""
2023-11-05 16:10:59,365:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/280836488786 HTTP/1.1" 200 1074
2023-11-05 16:10:59,367:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 05 Nov 2023 13:10:59 GMT
Content-Length: 1074
Replay-Nonce: M1qVDtAvqkt8mENmtrfhOWoHtCcxaxdUTWICsv0zuK4C6jn_Vxw
"identifier": {
"type": "dns",
"status": "invalid",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:connection",
"detail": "91.189.114.19: Fetching http://docs.module-electronic.ru/.well-known/acme-challenge/oLYffjvaxrMDy599VOIg679X-p-vsZq_LiBGcvyPK68: Connection reset by peer",
"status": 400
"token": "oLYffjvaxrMDy599VOIg679X-p-vsZq_LiBGcvyPK68",
"validationRecord": [
"url": "http://docs.module-electronic.ru/.well-known/acme-challenge/oLYffjvaxrMDy599VOIg679X-p-vsZq_LiBGcvyPK68",
"hostname": "docs.module-electronic.ru",
"port": "80",
"addressesResolved": [
"91.189.114.19"
"addressUsed": "91.189.114.19"
"validated": "2023-11-05T13:10:55Z"
2023-11-05 16:10:59,367:DEBUG:acme.client:Storing nonce: M1qVDtAvqkt8mENmtrfhOWoHtCcxaxdUTWICsv0zuK4C6jn_Vxw
2023-11-05 16:10:59,369:INFO:certbot._internal.auth_handler:Challenge failed for domain docs.module-electronic.ru
2023-11-05 16:10:59,369:INFO:certbot._internal.auth_handler:http-01 challenge for docs.module-electronic.ru
2023-11-05 16:10:59,372:DEBUG:certbot.display.util:Notifying user:
Type: connection
2023-11-05 16:10:59,446:DEBUG:certbot._internal.error_handler:Encountered exception:
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\auth_handler.py", line 93, in handle_authorizations
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\auth_handler.py", line 181, in _poll_authorizations
2023-11-05 16:10:59,446:DEBUG:certbot._internal.error_handler:Calling registered functions
2023-11-05 16:10:59,446:INFO:certbot._internal.auth_handler:Cleaning up challenges
2023-11-05 16:10:59,448:DEBUG:certbot._internal.log:Exiting abnormally:
File "runpy.py", line 194, in _run_module_as_main
File "runpy.py", line 87, in _run_code
File "C:\Program Files (x86)\Certbot\bin\certbot.exe\__main__.py", line 29, in <module>
sys.exit(main())
File "C:\Program Files (x86)\Certbot\pkgs\certbot\main.py", line 15, in main
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\main.py", line 1574, in main
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\main.py", line 1435, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\main.py", line 128, in _get_and_save_cert
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\client.py", line 445, in obtain_and_enroll_certificate
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\client.py", line 375, in obtain_certificate
File "C:\Program Files (x86)\Certbot\pkgs\certbot\_internal\client.py", line 425, in _get_order_and_authorizations
2023-11-05 16:10:59,490:ERROR:certbot._internal.log:Some challenges have failed.
