Connection Refused after updating SSL Cert?
I use LightSail on AWS to host a very basic website for an organization and I recently went to renew the SSL cert. The SSL cert was renewed fine through this instruction set: https://lightsail.aws.amazon.com/ls/docs/en_us/articles/amazon-lightsail-using-lets-encrypt-certificates-with-wordpress#link-the-lets-encrypt-certificate-files-in-the-apache-directory-wordpres
Domain: mtvfc1.com
I basically successfully renewed it and now it seems I am locked out.
Welcome to the forum @RumZ1337
PORT    STATE  SERVICE
80/tcp  closed http
443/tcp closed https
Everyone is locked out. Firewall? Router? Provider?
Ports 80 and 443 need to be open to start with.
I don't understand... would they close when I update an SSL Cert? If not, how do I open them?
To be clear, the website was fully functional until I went to renew the SSL cert.
To be honest I don't understand either. I don't use AWS or any of the tools you are using so someone else will have to step in to help you resolve the issue.
My contribution was to do some initial recon to verify your site (which is not accessible) and to peek at which ports were open.
Understood, this is all very bizarre. Renewing an SSL completely bricking the website.
After doing some digging, I found some information about.. starting apche? This was the result.
bitnami@ip-1:~ sudo /opt/bitnami/ctlscript.sh start apache AH00526: Syntax error on line 46 of /opt/bitnami/apache2/conf/bitnami/bitnami.conf: SSLCertificateFile: file '/opt/bitnami/apache2/conf/server.crt' does not exist or is empty apache config test fails, aborting Monitored apache bitnami@ip-:~
Further along, I found an error saying that server.crt doesn't exist when running this command line:
bitnami@ip-:~$ sudo /opt/bitnami/ctlscript.sh start
/opt/bitnami/mysql/scripts/ctl.sh : mysql (pid 990) already running
/opt/bitnami/php/scripts/ctl.sh : php-fpm (pid 1074) already running
After scanning the link you provided I think we will need a bunch more information. Most of what is needed are in the form provided when you opened this thread.
Welcome to the Let's Encrypt Community, Joseph :slightly_smiling_face:
Apache is failing to start because server.crt was removed somehow. Replace it with a self-signed (aka snake-oil) certificate then start apache.
This should help:
