Connection refused 80.. All sites not working
www.studybench.org
ss -tlnp
State Recv-Q Send-Q Local Address:Port Peer Address:Port
LISTEN 0 128 :22 : users:((“sshd”,pid=1341,fd=3))
LISTEN 0 128 :::22 :::
users:((“sshd”,pid=1341,fd=4))
Nginx + Easyengine
Ubuntu 16 LTS
Linode
no
What other commands have you also run?
[ss doesn't do anything to start nor stop services]
My certificates got expired…
Tried to renew with the following commands
ee site ssl-renew sitename…
ee site ssl-renew --all
none of that worked and gave me an error…
So i followed one of the so called solution which is renaming the old cert file and try to renew with the above commands… that didn’t work either. I deleted the old cert file and tried but still it says site already contains ssl…
Installed UFW and allowed 443 but still nothing…
Hi @prabhu
you need an open port 80.
Start with some basics:
then
That's
wrong, if you don't have a working configuration or a backup to restore the certificate. Then you can't restart your webserver. Then you have to remove the port 443 host complete or you have to install a self signed certificate, so your webserver can start again.
