Connection refuse and i don't know how to troubleshoot
My domain is:rcentrala.ddns.net
I ran this command: sudo certbot certonly --standalone
Please enter in your domain name(s) (comma and/or space separated)  (Enter 'c'
to cancel): rcentrala.ddns.net:18080
http-01 challenge for rcentrala.ddns.net
Failed authorization procedure. rcentrala.ddns.net (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: 84.117.138.115: Fetching http://rcentrala.ddns.net/.well-known/acme-challenge/aPfXXgl1vYWfFWN6HuyGlUY6FbmbIcGn1nul2ah9DTM: Connection refused
   Domain: rcentrala.ddns.net
   Type:   connection
   Detail: 84.117.138.115: Fetching
   Connection refused
My web server is (include version): CrowCpp (you can find it on github)
The operating system my web server runs on is (include version): Debian 10 (on raspberry pi Zero W)
My hosting provider, if applicable, is: no-ip (it's a free domain)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):0.31.0
Hi @Iuliean, and welcome to the LE community forum :slight_smile:
You must have a working HTTP site before it can be secured using HTTP-01 authentication.
But @Iuliean is using --standalone, where this is not a requirement (because Certbot would make its own HTTP server).
I'm surprised that Certbot accepted the :18080 in this input—maybe we changed that later so it doesn't?
In order to use --standalone this way, you do need to be able to accept incoming connections on port 80, as seen by the rest of the Internet, and they need to be forwarded to port 80 on your server. Do you have a router or firewall that is doing port forwarding? If so, has port 80 been forwarded to your server? If you're using a residential ISP here, do you know if your ISP allows incoming connections on port 80?
I'm not able to test for v0.31.0, but current Certbot versions simply drop the port from the URI and use the hostname.
I am not sure what happened but i think it was a port forwarding problem.
I had port 18080 forwarded and port 80 and 443 external mapped to 18080 internal and that may have confused things a bit
