Connection not secure but certificate seems valid?
Hi, followed all the steps and all looks good,
I get the "connection not secure" but when I click on the certifcate info it says it is valid?
leden.fanfaresintservatius.nl
sudo certbot --nginx
all was good, nginx configuration looked good
ubuntu 18.04
azure
certbot 0.31.0
Hi @remcohh
normally, that's a mixed content problem, not a certificate problem. But:
  • Your certificate is valid
  • and I don't see mixed content or a browser warning
Share a screenshot.
Or use Ctrl + Shift + I, open the console, there you should see the resources that are included via http, not https. Change that.
PS: Now checked - https://check-your-website.server-daten.de/?q=leden.fanfaresintservatius.nl - yep, Grade B, no certificate-problem, no mixed content. And the Chrome-Screenshot is happy too, so Chrome doesn't find mixed content.
Thanks for the help, this was weird, I refreshed the browser tab and the problem persisted but on a new tab it looks good now!
