Conflict with certificates with sub domains
this is the main domain
vmaportfolios.com
this is for staging
staging.vmaportfolios.com
for our database
ydb.vmaportfolios.com
sudo certbot --nginx -d staging.vmaportfolios.com
sudo certbot --nginx -d ydb.vmaportfolios.com
ubuntu 22.04 nginx
nginx configuration for staging
 server_name staging.vmaportfolios.com;
    ssl_certificate /etc/letsencrypt/live/staging.example.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/staging.example.com/privkey.pem; # managed by Certbot
nginx configuration for ydb
    server_name ydb.vmaportfolios.com;
    ssl_certificate /etc/letsencrypt/live/ydb.example.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/ydb.example.com/privkey.pem; # managed by Certbot
i follow the installation of certbot in here
and when i visit the site it says
This server couldn't prove that it's ydb.vmaportfolios.com ; its security certificate is from staging.vmaportfolios.com . This may be caused by a misconfiguration or an attacker intercepting your connection.
i am not sure where the error is or i misconfigure? the ssl certificate is actually different in my nginx configuration so how did this happen?
Thank you.
Hello @nelsondev, welcome to the Let's Encrypt community. :slightly_smiling_face:
Likely a nginx configuration issue.
For general nginx information you might find nginx documentation and https://forum.nginx.org/ helpful.
Please share the output of sudo nginx -T, that is a capitol T.
Edit:
Also using the online tool Let's Debug yields this WARNING
https://letsdebug.net/ydb.vmaportfolios.com/2029279
UnexpectedHttpResponse
WARNING
Sending an ACME HTTP validation request to ydb.vmaportfolios.com results in unexpected HTTP response 401 Unauthorized. This indicates that the webserver is misconfigured or misbehaving.
401 Unauthorized
<html>
<head><title>401 Authorization Required</title></head>
<body>
<center><h1>401 Authorization Required</h1></center>
<hr><center>nginx/1.18.0 (Ubuntu)</center>
</body>
</html>
Trace:
@0ms: Making a request to http://ydb.vmaportfolios.com/.well-known/acme-challenge/letsdebug-test (using initial IP 154.26.128.88)
@0ms: Dialing 154.26.128.88
@548ms: Server response: HTTP 401 Unauthorized
And curl shows
curl -i http://ydb.vmaportfolios.com/.well-known/acme-challenge/sometestfile
$ curl -i http://ydb.vmaportfolios.com/.well-known/acme-challenge/sometestfile
HTTP/1.1 401 Unauthorized
Server: nginx/1.18.0 (Ubuntu)
Date: Fri, 14 Jun 2024 01:19:36 GMT
Content-Type: text/html
Content-Length: 188
WWW-Authenticate: Basic realm="Restricted Access"
<html>
<body>
</body>
</html>
Edit:
The certificate being served https://decoder.link/sslchecker/ydb.vmaportfolios.com/443
shows " Hostname: close Doesn't match Common Name or/and SANs" for ydb.vmaportfolios.com
Hey @Bruce5051 thanks for your reply
here is the result for nginx -T
nginx: [warn] conflicting server name "ydb.vmaportfolios.com" on 0.0.0.0:80, ignored
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        types_hash_max_size 2048;
        # server_tokens off;
        # SSL Settings
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
        ssl_prefer_server_ciphers on;
        # Logging Settings
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # Virtual Host Configs
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
# configuration file /etc/nginx/sites-enabled/phpmyadmin:
## phpmyadmin for vma project
        #listen 80 default_server;
        #listen [::]:80 default_server;
        # SSL configuration
        root /usr/share/phpmyadmin;
        index index.php index.html;
                try_files $uri $uri/ =404;
                auth_basic "Restricted Access";
                auth_basic_user_file /etc/nginx/.htpasswd;
        location ~ \.php$ {
               include snippets/fastcgi-php.conf;
        #       # With php-fpm (or other unix sockets):
               fastcgi_pass unix:/run/php/php8.2-fpm.sock;
        #       # With php-cgi (or other tcp sockets):
        #       fastcgi_pass 127.0.0.1:9000;
        # concurs with nginx's one
        location ~ /\.ht {
               deny all;
    #listen 443 ssl; # managed by Certbot
    #ssl_certificate /etc/letsencrypt/live/ydb.vmaportfolios.com/fullchain.pem; # managed by Certbot
    #ssl_certificate_key /etc/letsencrypt/live/ydb.vmaportfolios.com/privkey.pem; # managed by Certbot
    #include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
    #ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
    if ($host = ydb.vmaportfolios.com) {
    } # managed by Certbot
    listen 80;
        #listen 80;
        #listen [::]:80;
        # SSL configuration
        root /var/www/staging/vankemeisha-school-system/public;
        index index.php;
        server_name staging.vmaporfolios.com;
                try_files $uri $uri/ /index.php?$query_string;
        location ~ \.php$ {
        location ~ /\.ht {
                deny all;
        #listen [::]:443 ssl ipv6only=on; # managed by Certbot
        ssl_certificate /etc/letsencrypt/live/staging.vmaportfolios.com/fullchain.pem; # managed by Certbot
        ssl_certificate_key /etc/letsencrypt/live/staging.vmaportfolios.com/privkey.pem; # managed by Certbot
#server {
#       listen 80;
#       listen [::]:80;
#       server_name example.com;
#       root /var/www/example.com;
#       index index.html;
#       location / {
#               try_files $uri $uri/ =404;
    if ($host = staging.vmaportfolios.com) {
        listen 80;
        listen [::]:80;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file. Contents are based on https://ssl-config.mozilla.org
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384";
# configuration file /etc/nginx/sites-enabled/vmaportfolio:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
        # SSL configuration
        root /var/www/production/;
        index index.php;
        server_name vmaportfolios.com www.vmaportfolios.com;
        location ~ \.php$ {
        location ~ /\.ht {
                deny all;
    ssl_certificate /etc/letsencrypt/live/vmaportfolios.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/vmaportfolios.com/privkey.pem; # managed by Certbot
#server {
#       listen 80;
#       listen [::]:80;
#       index index.html;
#       location / {
    if ($host = www.vmaportfolios.com) {
    if ($host = vmaportfolios.com) {
        listen 80;
        listen [::]:80;
i remove some part that are not relevant
I commented out the SSL certificates for YDB so that I can access the staging environment. The staging will work if I remove or comment out the SSL certificate for YDB. The same goes for staging: if I comment out the SSL certificate, the YDB will work.
Hi @nelsondev,
Please show the output of sudo certbot certificates
here
Found the following certs:
  Certificate Name: staging.vmaportfolios.com
    Serial Number: 31d8bc8b79556e991e43475c9c162066224
    Key Type: ECDSA
    Domains: staging.vmaportfolios.com
    Expiry Date: 2024-09-11 05:55:23+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/staging.vmaportfolios.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/staging.vmaportfolios.com/privkey.pem
  Certificate Name: vmaportfolios.com
    Serial Number: 4c541c4af75d96170c6c80a603bb29f7a68
    Key Type: ECDSA
    Domains: vmaportfolios.com www.vmaportfolios.com
    Expiry Date: 2024-09-11 05:50:48+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/vmaportfolios.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/vmaportfolios.com/privkey.pem
  Certificate Name: ydb.vmaportfolios.com
    Serial Number: 44ce13485b289715da2c9ec5cf98fd6ed91
    Key Type: ECDSA
    Domains: ydb.vmaportfolios.com
    Expiry Date: 2024-09-11 22:34:40+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/ydb.vmaportfolios.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/ydb.vmaportfolios.com/privkey.pem
Did you restart nginx after getting the new certificates?
Edit:
Also for ydb.vmaportfolios.com the only ssl_certificate is commented out.
I actually restarted many times, but not when I received the new certificates.
i commented out the blocks related to ssl for ydb.vmaportfolios.com so that i can access the staging.
I believe it is a misconfiguration, (side note: I've had a migraine headache all day)
so kindly wait for more knowledgeable Let's Encrypt community volunteers to assist.
Thanks @Bruce5051 i'll try to double check my nginx configuration.
I see a TYPO:
It's T time!
@rg305 WOW thank you for that! that solves my issue haha!
