Combining Wildcard and Regular Certificates
Hello,
I'm running CentOS 8, hosting mail and web on one server, and have successfully installed a regular certificate covering my domain example.com and www.example.com
I'd like to cover example.com, www.example.com AND mail.example.com.
I'd assume I need to combine a wildcard certificate along with the installed regular certificate.
Is this possible? I did some google searching and to my surprise I didn't see much regarding this, even though it seems like an obvious thing many people would want to do.
I have my mail server web mail app (Squirrelmail) setup at my mail.example.com via apache virtual host, and my www.example.com/exaple.com hosting my website.
Thanks!
-Shane
Why the wildcard? Why not just get a certificate with all three hostnames in it?
And to answer your actual question:
Yes, it's possible to mix all the kinds of certificate you'd like in Apache.. Doesn't mean you need to though, see my question above.
When I setup the certificate, it offered me two options, a regular certificate covering www.example.com and example.com, and a wildcard certificate but it specifically said it covered *.example.com but NOT example.com.
It's technically perfectly possible to include all the hostnames you've mentioned in this thread, including the wildcard, into a single certificate.
The question is: what piece of software offered you those options when "setting up" the certificate?
see, this is what I read on the certbot site:
" wildcard certificate
a wildcard certificate is a certificate that covers one or more names starting with *. and that will be accepted by a web browser for any subdomain name with any label in place of the * character. for example, a certificate for *.example.com will be valid for www.example.com, mail.example.com, hello.example.com, or goodbye.example.com, but not for example.com."
That's an explanation about how the wildcard hostname works. However, it does not directly say it's impossible to include example.com into the certificate too. That might be an oversight of the documentation though. To be honest, it should also explain the fix: just add example.com too :stuck_out_tongue: I'll see if I can open a Github issue for it.
Well it's all very confusing, I can see these types of issues hindering the stated goal of 'encrypting the web 100%!"
So I guess the question is how exactly can I expand my existing certificate to include mail.example.com, or how do I add another certificate along with my existing one?
I looked over the ssl.conf in the apache conf.d directory, but I didn't see letsencrypt's certificates referenced there. Certbot works in a way I haven't figured out yet..
Depends on how you got the certificate in the first place. Could you share the exact command you've used to get the certificate?
Oh, they are referenced in there somewhere :wink: If you have used certbot to install the certificates, it would have copied the VirtualHost section into its own file suffixed by -le-ssl.conf.
Sure:
I just followed the instructions for the default certificate installation:
  1. sudo dnf install certbot python3-certbot-apache
  2. sudo certbot --apache
Pretty sure that was it!
Just saw your reference to -le-ssl.conf. checking now.
OK, so that would mean you've used the apache plugin for authentication as wel as for installing. We can work with that :slight_smile:
You should be able to run certbot --apache again. It should give you the same question again: which hostnames would you like to certify.. Or something like that. It should be possible to select example.com, www.example.com and mail.example.com. Now.. If your certbot is new enough it should ask you if you'd like to expand the current certificate. That means you'll get a single certificate with all the three the hostnames in it.
It's also possible however, it generates a new certificate along side of your previous one. This isn't bad, strictly speaking, but it is very confusing. But nothing we can fix later :slight_smile:
So I'd suggest to run the certbot command just again and see what it asks :slight_smile:
By the way, opened an issue for the website: https://github.com/certbot/website/issues/660
Oh I see. Makes more sense now, I missed seeing the le-conf.ssl file
I'd hope I could just install another certificate (cert only download) with certbot and manually just add the second certificate below the first one in that file. I'm sure it wouldn't be that easy though, of course (nothing is).
Just saw your reply. reading now. Thanks for the help!
Well, that's possible too, of course. And isn't that hard. But I'm wondering why you might do that, when certbot should be able to do it for you?
You can generate a separate certificate for your mail subdomain if you'd like. Just select only that hostname when certbot asks you for the hostnames you want a certificate for.
oh my goodness it's asking:
1: example.com
2: mail.example.com
3: www.example.com
How clever!!
It also did this the first time you ran certbot, right? :stuck_out_tongue:
here:
certificate?
(E)xpand/(C)ancel: e
http-01 challenge for mail.decisionconcepts.com
Deploying Certificate to VirtualHost
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
    /etc/letsencrypt/live/
We'll I'll be. Amazing. I was prepared for a lot of nonsense.
except I restarted apache and it's not securing my mail.example.com site. hmm
It seems not to have installed the redirect from HTTP to HTTPS, because if you manually type https://, it works nicely.
Yup that was the reason I was refreshing the site that was preloaded with http://
It works!!!!
Thank you so much!!
well ok the non-redirect isn't optimal.
Is that normal?
I don't think so.. Might be something what is working perfectly in the current version of certbot. You're using your OS distro package manager.. They often lag behind tremendously.
You can add the redirect manually (just look what certbot put in the configuration file for the HTTP virtualhost of your main site and copy/paste it, while not forgetting to modify the hostname it looks for), or you might let certbot do it.. Not sure how though.. Perhaps by running certbot install --redirect --apache and select the three hostnames again. It should ask you something like "You already have a certificate, would you like to re-issue it? (no, you don't want to..) or to reinstall it? (yes, you want that)". But not sure what happens to be honest :stuck_out_tongue: I've never worked with certbot install before.
I'll try that. I also did some googling and there is information about how to force the redirect so I should be OK from here I think.
Thanks again!
