Hi I found a similar topic but I couldn’t tell if it was relevant to my issue as well. I have a Wordpress site running on a Cloudways server. Let’s Encrypt Certificate works great but the auto-renewal always fails. I have to rename the .htaccess and then the renewal works. This last time I tried commenting out some of the security commands I have in there (deny access to wp-config and wp-login) but it still failed until I renamed the whole file. I didn’t want to keep trying things in case there was a limit to the number of failed renewal attempts.
You can put this at the top of any .htaccess
file to prevent issues:
RewriteEngine On
RewriteRule ^.well-known/acme-challenge - [L]
It will prevent any subsequent rewrite rules from interfering with requests to the HTTP challenge resource.
Excellent thank you! I will add that and see if it works in 3 months!
