Amazon CF does not work with Let’s Encrypt. Is there any workaround for the same? Added the following code to nginx.conf file ECDH+AESGCM:ECDH+AES256:ECDH+AES128:DH+3DES:RSA+3DES:AES128-SHA:!ADH:!AECDH:!MD5;
I’m still getting errors connecting to my CF.
has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
Is there any fix for this issue apart from not using CF?
This isn’t related to Let’s Encrypt or SSL/TLS in general.
From the looks of it, you’re trying to request a cross-origin resource (i.e. request a site on a different domain) with JavaScript. That’s not possible unless you set appropriate headers. More information on this on MDN.
