app.weally.org
1. weally@vps-cb318f69:~/production/weally_conf$ docker exec -it nginx certbot -d app.weally.org --config-dir ~/.certbot/config --logs-dir ~/.certbot/logs --work-dir ~/.certbot/work
2. weally@vps-cb318f69:~/production/weally_conf$ docker exec -it nginx certbot -d app.weally.org
- Saving debug log to /home/weally/.certbot/logs/letsencrypt.log
Unable to recover files from /home/weally/.certbot/work/temp_checkpoint
Incomplete or failed recovery for /home/weally/.certbot/work/temp_checkpoint
Unable to revert temporary config
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /home/weally/.certbot/logs/letsencrypt.log or re-run Certbot with -v for more details.
2.Saving debug log to /var/log/letsencrypt/letsencrypt.log
The following error was encountered:
[Errno 30] Read-only file system: '/etc/letsencrypt/.certbot.lock'
Either run as root, or set --config-dir, --work-dir, and --logs-dir to writeable paths.
What is weired, is that I could not find the above folders (I wanted to chown them or delete them to restart from scratch)
My web server is (include version): nginx:1.21-alpine (through docker)
The operating system my web server runs on is (include version): Ubuntu 21.04
My hosting provider, if applicable, is: OVH (Kimsufi)
or certbot-auto --version
if you're using Certbot): certbot 1.27.0
