Certsage will not accept my password
My domain is: nuclix.net
I ran this command: certsage.php
It produced this output:Trouble! Could not find password.
My web server is (include version):Apache?
The operating system my web server runs on is (include version):Linux
My hosting provider, if applicable, is:namecheap.com
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):cpanel
Certsage will not accept my password. I assume it wants my namecheap password. I have tried my password to namecheap, namecheap control panel, my application on namecheap. I have tried old passwords. Nothing seems to work.
That is not correct. See the docs:
Specifically:
Enter your password into the Password box from your password.txt file found in your CertSage data directory, which is located in the parent directory of the directory where you uploaded certsage.php.
Thank you. That seemed to work. I should have RTFM before assuming.
