My domain is: literaturhaus.at
I ran this command:certbot-auto certonly --server https://acme-v02.api.letsencrypt.org/directory --manual --preferred-challenges dns -d 'literaturhaus.at,*.literaturhaus.at'
It produced this output: Found the following certs:
Certificate Name: literaturhaus.at
Serial Number: 4c3af8caf2be2b0db1ccfb8e03f1b0037c6
Domains: literaturhaus.at *.literaturhaus.at
Expiry Date: 2021-12-22 19:34:37+00:00 (VALID: 84 days)
Certificate Path: /etc/letsencrypt/live/literaturhaus.at/fullchain.pem
Private Key Path: /etc/letsencrypt/live/literaturhaus.at/privkey.pem
The operating system my web server runs on is (include version):Debian GNU/Linux 8.11 (jessie)
My hosting provider, if applicable, is: (own server)
or certbot-auto --version
if you're using Certbot):certbot 1.9.0
now i have rate limit, i put the correct txt record in the name server, restartet all but it didn't work.
normally i have no problems, i use certbot-auto with this configuration since years.
thanks for helping
