My domain is: agenciacaput.com
I ran this command: the command is with virtualmin
Parsing account key…
Parsing CSR…
Registering account…
Already registered!
Verifying www.agenciacaput.com.br…
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 235, in
main(sys.argv[1:])
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 231, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, args.dns_hook, args.cleanup_hook, log=LOGGER, CA=args.ca)
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 184, in get_crt
domain, challenge_status))
ValueError: www.agenciacaput.com.br challenge did not pass: {u’status’: u’invalid’, u’validationRecord’: [{u’addressesResolved’: [u’192.99.56.202’, u’2607:5300:201:3000::39f3’], u’url’: u’http://www.agenciacaput.com.br/.well-known/acme-challenge/-9ZlsmIXtgg4Rb3QpHI0E-peDAI87mCE1i6TCf3_ge4’, u’hostname’: u’www.agenciacaput.com.br’, u’addressesTried’: [], u’addressUsed’: u’2607:5300:201:3000::39f3’, u’port’: u’80’}], u’keyAuthorization’: u’-9ZlsmIXtgg4Rb3QpHI0E-peDAI87mCE1i6TCf3_ge4.5gP9cxDS751mabEx7CPLIHcilNPgABhdZEdzNM8MbJE’, u’uri’: u’https://acme-v01.api.letsencrypt.org/acme/challenge/kZFzASRnbWe_2PxEMTIAjn0-85gj9V3oSV-ycZDjcJU/2570364906’, u’token’: u’-9ZlsmIXtgg4Rb3QpHI0E-peDAI87mCE1i6TCf3_ge4’, u’error’: {u’status’: 400, u’type’: u’urn:acme:error:connection’, u’detail’: u’Fetching http://www.agenciacaput.com.br/.well-known/acme-challenge/-9ZlsmIXtgg4Rb3QpHI0E-peDAI87mCE1i6TCf3_ge4: Timeout’}, u’type’: u’http-01’}
My web server is (include version): nginx the last i think
The operating system my web server runs on is (include version): centos 7
My hosting provider, if applicable, is: ovh.com
I can login to a root shell on my machine.
I’m using a control panel to manage my site: virtualmin
The problem is, everything that i think is tested, but LE don´t work either… I can access the acme challenge, i have created a test.txt file on acme-challenge… i will also need help to use the redirection from http to https because when i use it, i got a 301, so i disabled it temporarly, to make the test, it won´t work either… i dunno what is going on… just need help, the script i use for the acme challenge is the letsencrypt-acme-challenge.conf, and it is working, as it sends the file correctly… the redirection i was using is this:
#if ($scheme = http) {
rewrite ^ https://$host$request_uri? permanent;
any help will be most apreciated! tnx for your time ppl.
