Certificates can be updated even with a nonsensical manual-auth-hook script
I will try to renew certificates with Certbot, but don’t understand what manual-auth-hook should be used.
If the manual-auth-hook script is a nonsensical command, certificates can be renewed with it.
I have a question.
・Why is it possible to renew the certificate even with manual-auth-hook, which obviously does not work?
・When is a normal manual-auth-hook necessary?
Thanks.
*.ken2.smartdb.jp
certbot certonly --manual \
--server https://acme-v02.api.letsencrypt.org/directory \
--preferred-challenges dns \
-d *.mydomain.jp \
-d mydomain.jp \
-m my@mailaddr.jp \
--agree-tos \
--manual-public-ip-logging-ok
Then
certbot renew --force-renewal --manual-auth-hook "echo abcd"
(certbot certonly)
dns-01 challenge for ken2.smartdb.jp
Please deploy a DNS TXT record under the name
_acme-challenge.ken2.smartdb.jp with the following value:
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Before continuing, verify the record is deployed.
Press Enter to Continue
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
(This must be set up in addition to the previous challenges; do not remove,
replace, or undo the previous challenge tasks yet. Note that you might be
asked to create multiple distinct TXT records with the same name. This is
permitted by DNS standards.)
   /etc/letsencrypt/live/ken2.smartdb.jp/fullchain.pem
   /etc/letsencrypt/live/ken2.smartdb.jp/privkey.pem
   Your cert will expire on 2020-10-05. To obtain a new or tweaked
   version of this certificate in the future, simply run certbot
   again. To non-interactively renew *all* of your certificates, run
   "certbot renew"
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
(certbot renew)
Processing /etc/letsencrypt/renewal/ken2.smartdb.jp.conf
new certificate deployed without reload, fullchain is
  /etc/letsencrypt/live/ken2.smartdb.jp/fullchain.pem (success)
(Use the generated certificate on another web server.)
# uname -a
Linux 96d27eaf7902 4.19.76-linuxkit #1 SMP Tue May 26 11:42:35 UTC 2020 x86_64 Linux
# cat /etc/issue
Welcome to Alpine Linux 3.11
Kernel \r on an \m (\l)
I don’t know.
# certbot --version
certbot 1.0.0
It is probably due to authorization reuse/caching on your Let’s Encrypt account - Let’s Encrypt does not force you to repeat authorizations for the same domains for some period of time (~30d, subject to change). Instead, it skips the authorization bit and proceeds immediately to issuing the certificate.
If you want to make sure that your authorizations are fresh and your hooks are tested properly, use --dry-run. It will also prevent you from blowing your rate limits and wasting Let’s Encrypt’s resources.
I understand that I need to authenticate again for my domain if at least 30 days have passed since I ran the certonly command.
Thank you, _az!
