Certificated not Trusted Chrome / Safari. Chain issues incomplete
Hi, I have a web running in a DigitalOcean droplet. I created a certificate for my domain and subdomains long ago, I usually renew them every 3 months. Never had an issue, apart from having to remember to stop nginx (to free port 80) and then run sudo certbot certonly --nginx -d [...], sudo certbot renew --dry-run
Now I've noticed that my certificate is no longer secure when I try to access my web from Chrome or Safari. I tried going to SSL Server Test: app.superenvios.pe (Powered by Qualys SSL Labs) in order to get a certificate report. it seems to show that there is no DNS CAA.
I don't know why would that change suddenly as I have not updated any configuration recently. I'm not too familiar with what a CAA is, so I'd appreciate any suggestions/help trying to address this issue.
My domain is: app.superenvios.pe
My web server is (include version): Nginx
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.31.0
Hi @mvergaray,
The CAA warning is an unrelated issue which isn't important here.
The message that's most likely to be important in that test is
Chain issues Incomplete
It seems your server isn't serving the intermediate certificate, which is especially important now because the old intermediate certificate that would have been used in the past has just expired.
Did you point your nginx configuration at the /etc/letsencrypt/live/app.superenvios.pe/fullchain.pem file, or did you copy this elsewhere on your system?
Hi @schoen , thanks for the replay.
This is how I have configured my sub domain in nginx. I set ssl_certificate and ssl_certificate_key. I don't remember pointing anywhere to the fullchain.pem file. What should I do there?
listen 443 ssl;
listen [::]:443 ssl;
client_max_body_size 200M;
server_name app.superenvios.pe;
ssl_certificate /etc/letsencrypt/live/superenvios.pe/cert.pem;
ssl_certificate_key /etc/letsencrypt/live/superenvios.pe/privkey.pem;
    proxy_pass http://localhost:3000;
    proxy_http_version 1.1;
    proxy_set_header Connection 'upgrade';
    proxy_set_header Host $host;
    proxy_cache_bypass $http_upgrade;
Change cert.pem to fullchain.pem and restart nginx. It should work then. :slight_smile:
Awesome man, spend the whole day renewing it and diving in the web for this. I appreciate your help!
Would you be willing to give me a little more of context on what's the different between both files and why would I need to change the reference suddenly?
Thank you so much!
I'm glad it worked for you!
Yes, there's a thing called an intermediate certificate (also called chain certificate or issuer certificate) which is used by the browser in validating certificates that web sites present. Usually intermediate certificates are supposed to be served by the web server. But most browsers also cache ones that they've seen before and attempt to use those in validation, especially if they don't receive a relevant intermediate certificate or certificates from the web site. This means that a site that doesn't provide the complete validation information will often still work on many web browsers, especially if it uses a relatively common and popular certificate authority, because those browsers will often know about the relevant intermediate certificates used by that certificate authority.
In this case, an intermediate certificate that was previously used by Let's Encrypt has just expired, which means that browsers that knew about that one before should no longer trust it. Let's Encrypt has been sending a new recommended intermediate certificate for a long time (many months!) and Certbot always saves the currently-recommended one in an appropriate place in /etc/letsencrypt/live, but if you manually set up your nginx or other web server application, you may not have referenced a file containing it—which was the case with your configuration.
In this case fullchain.pem is the combination of cert.pem (your certificate) plus chain.pem (the recommended chain of intermediate certificates). Certbot documentation always suggests using fullchain.pem instead of cert.pem, unless you're using some older software (like Apache 2.2 or certain chat applications, for example) that doesn't understand this combined format.
This sounds like my problem. My certificates work on my new Macbook Air and on iPhone, but not on my old iMac 24 inch with El Capitan.
I have a windows 2012 R server and I used win.acme when I updated the certificates.
The problem address is atervinnmera.se and manmade.se
I don´t know where I can find the cert.pem file so I can change it to fullchain.pem? Thanks.
