today, I try to make certificate for my server with sub domain.
I’ve 4 subdomain: chat, issues, confluence, repositories
For each subdomain, I make this command letsencrypt certonly --agree-tos --rsa-key-size 4096 -m webmaster@osames.org -d <DOMAIN>.osames.org --renew-by-default
In apache 2.4, each virtualhost contains SSLEngine On SSLCertificateFile /etc/letsencrypt/live/<DOMAIN>.osames.org/fullchain.pem SSLCertificateKeyFile /etc/letsencrypt/live/<DOMAIN>.osames.org/privkey.pem SSLProtocol all -SSLv2 -SSLv3 SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS SSLHonorCipherOrder on
But, if I use portecle (java app) to check SSL/TLS connection, the response for chat.osames.org and issues.osames.org is the certificate for confluence.osames.org
(here picture: http://i.imgur.com/TjmdzAh.png)
How to make the certificate for each subdomain match the one requested ?
This seems to indicate that portecle does not support SNI prior to version 1.10 (released 2016-02-04). Without SNI, you’re effectively limited to one certificate per IP address.
SNI support is pretty good nowadays. If you really need to use software that does not support SNI, you can instead obtain one certificate that covers all your domain names (often called a multi-SAN certificate). You can do that by simply passing multiple -d arguments to the client, i.e. -d confluence.osames.org -d issues.osames.org ..., or alternatively get additional IP addresses and use one per certificate.
I see with Atlassian why have one error: 2017-02-15 18:05:03,272 http-bio-8443-exec-4 ERROR anonymous 1085x566x1 - 213.47.56.124,0:0:0:0:0:0:0:1 / [c.a.g.r.internal.http.HttpClientFetcher] Unable to perform a request to: https://issues.osames.org/rest/gadgets/1.0/g/messagebundle/und/gadget.common%2Cgadget.project javax.net.ssl.SSLPeerUnverifiedException: Host name 'issues.osames.org' does not match the certificate subject provided by the peer (CN=cloud.osames.org)
Because I verified my java keystore and he have the good informations.
